Question about Mitsubishi WS-55311 55" Rear Projection Television
Just got it (used) power problem?
Came on and appeared fine but front buttons did not work properly unplugged and moved now it wont turn on and when I plug it in the power light comes on then flashes 3 times then it does nothing
  1. turn your tv on with remote control
  2. go to menu select front button lock
  3. select off to restore the operations of the front panel operations
  4. the front panel lock is a feature that lets you disable the front panel to prevent children from changing settings by accident
  5. if this doesnt work i would suggest contacting a service repair tech.
Posted on Jun 09, 2008
SOURCE:
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
My LG blu ray 3-D dvd player just stopped working. all it says is boot. I unpluged it but still just says boot. It was working fine. Now it wont turn on at all just says boot, its said boot for the pa
My LG 670 also said 'boot' after a upgrade attempt and appeared stuck there. I searched LG support for a factory reset option, which is: Disconnect the LG power cable from the wall / power stripHold down the power button the front of the player for 30 secondsRe-insert the power cordTurn the player back on. Note: my player showed 'boot' again for a few minutes, then shut off. When I turned it on again, it went through the normal power up cycle, then shut itself off (weird). I turned it on again. So far, so good.
Apr 24, 2012 | LG BX580 Blu-ray 3D Player
The on button light flashing only.
Welcome to FixYa!
A blinking power light for HP DeskJet D2360 means 3 things.
1. The cover is open.
Close the printer cover properly.
2. There is no loaded paper or the paper in the paper tray is not loaded properly.
Load the paper properly in to the paper tray.
3. Paper Jam and/or Carriage Jam.
Follow the instructions below.
> Turn of the printer and unplug the power cord at the back of your printer.
> Open the back door of the printer.
> Remove any paper or foreign object that you see gently.
> Close the back door of the printer.
> Open the front cover of the printer
> Move the carriage (where the ink cartridge sits) left and right. Make sure that it moves freely.
Remove any paper or foreign objects that is preventing it from moving freely.
> Close the front cover.
> Connect back the power cord.
> Turn the printer on using the power button.
If it doesn't not resolve the issue, reset the printer.
1. Turn the printer on.
2. Unplug the power cord at the back of your printer while it is on.
3. Unplug the USB cable at the back of your printer while it is on.
4. Wait for 2 minutes.
5. Connect back the power cord and USB cable.
6. Turn on the printer using the power button.
I hope this will help.
Thanks for using FixYa and keep me posted.
Jas247
Mar 10, 2011 | HP Deskjet D2360 InkJet Printer
Remote control and buttons on top of tv wont work!
you unplugged the front panel with the buttons on it and the remote reciever
you have to slide the chassis out
reach in to the front and replug the front panel to the plug from the main board
then slide all boards back in place
Aug 26, 2009 | Sony KV-35V42 35" TV
Error Code 077-300 close front cover
I would suggest, turning off the printer. Unplug the printer for about 3-5 mintues and hold the power button for a few seconds causing ALL power to disapate from the printer. Also known as power cycling. Please just insure the toner tray is properly inserted into the printer and close covers. Plug printer directly into the wall. Power it up and see if that helps your issue. If this helps you please rate my solution.
May 21, 2009 | Dell 3010cn Laser Printer
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Jan 03, 2009 | HP Compaq Presario C304NR Notebook
Power Button Isn't Working Properly
There might be possibility that the cable connected from the front board on/off socket which connects to the motherboard is not connected properly , so for this either you will have to open up the chassis of the laptop and then check that whether it is fine or not.
Other wise
Take a magnet and move it along the power on /off button for 1 minute ( on the laptop ) , this will remove any static charge effecting the laptop ( very rare scenario ).
Or take it to a technician.
Also check the battery.
Jun 05, 2008 | Toshiba Satellite A45-S250 Notebook
Canon pixma 530
unplug it from power and plug it back in.
if that doesnt work try unplugging it and GENTLY try moving the ink carrage to make sure it isnt in some odd position that the porinter cannot detect.
IF the carrage is properly seated on the one side of the printer it is normal for it to be locked and seated on pads that keep the ink from drying out.
May 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
My t.v. been sitting for a while and now the light in the power button comes on but the t.v. itself wont turn on.
as you say it was ok before it was moved. so thre is a possibility that some parts must have gone loose while shifting .
Sep 17, 2007 | RCA TruFlat 27F520T 27" TV
Help front panel wont work and treble +10 keeps coming up by itself
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Sep 21, 2006 | Yamaha HTR-5650 Receiver
Open Questions:
See all Mitsubishi WS-55311 55" Rear Projection Television Questions
Mitsubishi WS-55311 55" Rear Projection Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
