Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error SC320 Ricoh Copier
My Copier is Ricoh Aficio 1013.
When I launch copy, it shows Error SC320.
Please help how to fix this problem.
Thank you.
  • Anonymous Mar 16, 2014
    Aficio 1013 giving blank copies but the internal prints are fine what could be the cause of this? Cedric
Anonymous
Level 2:
  • Expert 162 Answers
  • Posted on Dec 07, 2009
Anonymous
Expert
Level 2:
Answers
162
Questions
Helped
130985
Points
285
Change the polygonal motor of the laser.
A
Anonymous
Laser motor is cooked
5helpful
3answers
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
1helpful
2answers
I have problem with Ricoh Aficio 1113, error code sc320
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
1helpful
2answers
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
2helpful
3answers
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
2helpful
2answers
Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
4helpful
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
2helpful
5answers
Ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
10helpful
4answers
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
