Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag washer is a bit older its a Dependable Care model 3cycle
Clothes are more wrinkled and not sure why, I have lost the agitation in the regular wash cycle but the permanent press cycle seems to work properly. I have recently added the hoses with a restrictor that shuts off waterflow if it bursts. is it posssible that the reduced waterflow is the cause or is it the agitation feature?
  • 240 Answers
The agitation problem is probably caused by a bad timer. Also, on the wrinkling issue, be sure that your hoses are connected right (hot to hot, cold to cold). Have found out that if they are switched, you would wash in wrong temp. Doubt that a hose would cause problems because washer wont start unless the proper amount of water is in the tub (also could be a timer problem). Good Luck!!! Jim
Posted on Sep 09, 2007
Remove dual agitator
The agitator in your Maytag Dependable Care washer uses a back-and-forth motion to move your clothes from the top of the washtub to the bottom and back to the top again. The fins on the side of the agitator help facilitate this movement. When one of the fins sustains damage or the agitator fails to move, you must remove the agitator to make the necessary repairs.Disconnect your Maytag Dependable Care washer from the electrical wall outlet. Turn off the valves supplying water to the appliance.
2 Open the washer's lid to access the agitator. Look for a 1/4-inch hex screw recessed in an opening about three-quarters down the side of the agitator.
3 Insert a 1/4-inch nut driver into the opening in the side of the agitator. Fit the nut driver over the head of the screw. Turn the screw counterclockwise to remove it.Grab the bottom of the agitator with both hands. Pull the agitator from the bottom of the washtub.
  • Nut driver, 1/4-inch
Sep 29, 2016 | Washing Machines
Maytag Dependable Care model LAT9634AAE During
there is probably some sort of debris in the water pump a button or other items blocking the flow of water please make Shure to try and turn the water pump by hand in order to free any obstruction eric
Dec 25, 2017 | Maytag Dependable Clean Top Load Washer,...
Where is the lid switch for reset on a maytag dependable care washer
where is the lid switch for reset on a maytag dependable care washer
Dec 19, 2009 | Maytag Dependable Care LAT9706
Water problem
Apr 01, 2009 | Washing Machines
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Build up of scum on inside of agitator
You should be able to remove the agitator,also try adding or spraying limeaway or clr on it during the rinse cycle
Apr 27, 2008 | Maytag Dependable Care LAT9416
Maytag Atlantis MAV6451 Top Load Washer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
