Question about Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive
How to open the external hard drive case.
I have a seagate 100 gig external drive that I am trying to get into. I can not find the proper bit to get the four screws off with. Does anyone know the bit size and where to get one.
    Brigadier General:
  • 6,966 Answers
Hi, Most Seagates HDs uses Torx (type of screw head characterized by a 6-point star-shaped pattern). TORX sizes are using letter "T", followed by a number. A smaller number corresponds to a smaller point-to-point dimension of the screw head. These are also used by cellphones but smaller sizes. Normally you can buy a plastic box set containing 6 Torx drivers of varying sizes, hopefully one will fit you HD. However, if you are referring to the enclosure of the actual HD, they might or might not be using the same kind of screw. Hope this be of help/idea. Post back should you need further information. Good luck and kind regards.
Posted on Sep 09, 2007
SOURCE:
I have a Seagate external hard drive model # 9w6044-540. I need to know what kind of drive it has, how many gigs it is and what size disc it uses.
If you take it out of the case, there will be a sticker on the drive with all the info. I do know it's quite a few years old tho. Somewhere around 160 gig I think.
Feb 01, 2015 | Seagate Computers & Internet
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Jun 16, 2017 | Seagate Computers & Internet
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a seagate external harddrive that my father gave me can it be locked? the harddrive is 160gb it is about 2yrs old gray and black casing
When you say lock the drive are you asking to lock access to the drive entirely when you disconnect it from your computer no one can access your files if they find the drive and try to put it on their computer and open it,
Apr 18, 2009 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
Jan 11, 2009 | Computers & Internet
Problem with seeing files on external Hard drive
What has happened is that your file system on the hard drive became corrupt becasue windows had not updated the MFT on the drive. THe MFT is a table of contents regarding whats on your drive.
What happened is similar to someone cutting out a few pages of the table of contents in a book that has a lot of pages.
Windows tried to fix this stupid programming method by asking people to always use the "safely remove hardware" button in the taskbar to force it to update the MFT.
In this case yur a victim of the Hard Discs MFT not updating properly probably because software was accessing the drive when it was disconnected from the machine.
You need to run chkdsk to have it rebuild your MFT.
http://support.microsoft.com/kb/315265 <-- How to perform Check disk
*NOTE: Remember to use the drive letter that the USB External is on.. Not just type CHKDSK. It will default to drive C to scan for errors. ex: c:\chkdsk g: (where g is the drive your external usb is)
If you get an error like "CHKDSK is not available for RAW drives.. see my notes below.
Beware that it will take a LONG TIME to perform this procedure.
If this doesn't fix it.. contact a data recovery specialist.. It's worth the cost. There are two types. Simple and Advanced.
Simple= recovering files your deleted with the delete button (fairly easy with the right software)
Advanced = recovering files from a hard disk crash or file system corruption. (Not easy and very time consuming)
Nov 04, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
In this case the MOST effective way is to try some data recovery program to see if it can help rescue your data on your Seagate external.
Oct 24, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate (ST9100801U2-RK) (9W3638556) 100 GB Hard Drive Logo
537 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
