Question about Toshiba 56HM195 56" Projection HDTV
TV won't stay on
I have a 56" Toshiba Rear Pro. HDTV...and when I try to turn it on it keeps turing itself back off. The sound will come on, but no picture. Then the Time Rec light starts flashing and it turns itself right off. I know I should "pitch it", but any suggestions to how I can fix it for now? Thanks
  • 1 more comment
  • dreadnight Nov 23, 2007
    replaced the lamp and the tv will not come on.
  • Anonymous Mar 13, 2008
    I as well replaced the lamp amd all i get is sound then it powers down.
  • VanillaZeus Jun 08, 2008
    same problem happening with mine. Anyone know the problem after getting it fixed?
Same problem happening with mine. Anyone know the problem after getting it fixed?
Posted on Jun 08, 2008
    Sergeant:
    Champion:
  • 375 Answers
Sounds like a deflection/convergence fault.requies service
Posted on Sep 08, 2007
SOURCE:
Samsung 56" Model HL56A650C1FXZA will
Mine is doing the same... anyone find a solution?
Jul 05, 2011 | Samsung HL56A650 56 in. TV
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Toshiba 56hm66 New lamp worked last night, wont boot up again
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
michtech
Feb 12, 2009 | Toshiba 56HM66 56" Projection HDTV
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
No picture, no sound on my Samsung 56" Projection TV
You probably need to replace the lamp. It's about $150, and if you buy it with the housing, it's a really easy fix, just unscrew and pull out the old one, and pop the new one in. Go here:
www.dlplampexpress.com
Jul 30, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Projection tv toshiba
my tv did the same thing except it is a 57in hdtv
May 21, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 56HM195 56" Projection HDTV Logo
213 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
