try pairing the phones with a hands free device, if they pair and work, the problem is the gps, also remember that most phones can only pair with one bluetooth device at a time , so if you pair to the gps then pair to a handsfree device, the gps connection will be lost .
I've got MY65T working on an iPhone 3GS. I previously had the problem where it would pair and retrieve phone book, but not transmit or receive voice from my iPhone when making a call.
The last thing I did that fixed it was to remove the bluetooth pairings and "reinstall software on your navman". I don't know if this may remove some of your settings / POI / etc. This was a new purchase so I didn't have anything to lose.
Before doing this I had upgraded the navdesk software to 7.30, and installed the latest firmware for MY65T. Firmware is located at http://www.navmansupport.com.au/Software/My%20Series/MY65T/MY250___352.htm
Details: -remove the phone bluetooth pairing from the Navman from Settings / Bluetooth / My Paired Devices / [your phone] / delete -remove the bluetooth pairing from your phone's settings -connect navman to PC and launch navdesk -click "My Navman" / "Reinstall software on your Navman" -download the install file if prompted -accept the reinstallation prompts and complete reinstallation -set your phone to discoverable over bluetooth (just keep it on the Bluetooth settings screen on iPhone) -go to Settings / Bluetooth /" Search new devices" on your Navman -click your phone's name on the navman's discovered devices -enter the PIN onto your phone when prompted and accept the pairing. This takes a little while. -test handsfree!
Try Start Settings System GPS and tap ON before starting the satnav program. Not all programs automatically switch on the GPS. On hitting ON yellow light top left starts flashing. Now start your satnav program..
The Blackberry is not compatible, there is no patch to make it work. Have a look at the listed phones Navman have tested on their website. Try and see if Blackberry have any updates, that could maybe help the connection.
you need to pair your mobile to your navman through your bluetooth, then it will ask you to type in a piar number it should be 1234 and then it will work.
I got the pairing code via searching the internet it is 0000 and worked just fine. Now however I get an "Unable to connect message". Sanyo tech support is very hard to get a hold of.,.
try 0000 thats the default pin code for bluetooth, not unless you change it before. you can call blackberry support as well to ask what is the default pin.
