Question about Rancilio Silvia Espresso Machine
Rancilio silvia I have a rancilio silvia espresso machine and the boiler is not heating up. What can the problem be?
  • caillou Nov 21, 2007
    The espresso boiler produces a cool and clear brew; the machine top does not heat at all; the froth boiler works just fine. What to do?
It more likely is the automatic boiler shut off if the boiler overheats. Just reset the boiler.
Posted on Nov 08, 2007
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Posted on Oct 06, 2007
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
No Hot Water
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Mar 17, 2008 | Rancilio Silvia Espresso Machine
The rancilio coffee machine failed to heat up no steam or hot water but all switch lights work and water pumps through
Remove the top panel, and check the thermostats on the boiler there are 3 of them. One needs to be reset.
Aug 09, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
My Rancilio miss Silvia coffee machine is not heating water any more. Which part should be replaced? Thank you
Could be a switch, a themostat, a wire connection, or the boiler element. Someone with a volt-ohm meter will have to help you.
Once you figure it out, you can get the parts here
Rancilio Silvia Parts
Dec 09, 2009 | Rancilio Coffee Makers & Espresso Machines
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio silvia espresso coffee machine
Esprosso Parts sells all parts for the Rancilio Silvia, including some customized and modified parts.
Mar 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
394 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
