My westinghouse 42" 1080P lcd hdmi ports just stopped working. I've tried plugging into different HDMI ports and none of them work.
This happened before and then it started to work again suddenly.
My HDMI ports still do not work after many resets and unplugging the power cord. All other inputs work. I currently have my DVD and cable box hooked up to the 3-wire component input. Note that this unit is a refurbished unit they sent me last month after my new unit failed 6 months after I bought it.
Does anyone have any insight here? I am not returning it, so if I cannot get it to work I'll just suffer until it fails.
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds.
That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
The above mentioned ide by seanpf worked like a charm I have had this happen multiple times.
Just do a hard reset manually on TV and it will start working, got it fixed by hard resetting
Same issue here! It seems liek the HDMI circuit must have just failed, of course the one year warrenty expired. I guess im not buying off-brand next time, but the TV works great otherwise so I willl ride it out a it longer before I drop the cash for a new set. Too bad.
