Question about Mustek DV5300SE DIGICAM Digital Camera
It states please remove usb cable
Problem is there is no usb cable plugged in to it?
How do i delete pictures on my mustek DV5300se new camera to me no instruction book
Posted on May 10, 2008
SOURCE:
Mx7600 error code 5c20 Problem
hi..............
Please remove all cartridges and print head. Using a moist cloth clean the golden contacts on Print head as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the Print head and cartridges.
Now see if its working fine.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX7600 Office All-In-One Printer
I have a fuji z20fd, and have used it many many times to uploads pictures onto my computer before, but now they wont? So I dont understand. It says in the usb icon that the usb cable is not plugged into...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 15, 2011 | Fuji Finepix Z20fd Digital Camera
HP C8189 All in one printer....Error Oxc 19a0005
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. Use a moist cloth to clean the nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
Then plug in the cartridges.
Now see if its working fine. Let me know.
Dec 02, 2010 | HP Photosmart C8180 InkJet Printer
Black ink is leaking inside the machine and smearing the back of the printed page
Please do this :
Dec 02, 2010 | Canon PIXMA MP970 InkJet Printer
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Nov 10, 2010 | Polaroid Cameras
USB not recognized
Since you plugged out without safe remove (while many people do this and don't get any problems, it is still HIGHLY unsafe!) so you probably screwed it up. Specially if it was in active state doing a transfer.
Try it on a different PC, if it doesn't work, you should contact your vendor.
Even if you have warranty, i doubt it will come to use because it was "your" mistake of not safe removing.
May 24, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
"Do not remove USB cable" message
The only way you can restart the phone is to remove the battery and then after that the phone should be back to its working state....
Jul 10, 2009 | Sony Ericsson W300 Cellular Phone
I have a HP Photosmart C4240 All-in-One printer. When I try to scan something it states that the USB is not connected. Everything is plugged in and it use to work. Any suggestions?
Try plugging the USB into a different port on your computer.
Try it in another computer.
Try a different USB cable.
Uninstall the unit from Start, control panel, Add Remove Programs.
Turn off computer.
Start computer, place driver disk in drive.
See if the computer will recognizes it and sets it up again....
Jul 07, 2009 | Office Equipment & Supplies
Webcam not found - but plugged in to USB
mmmmm
u need to try to connect it to another PC and try to see if the other computer see it or not, if yes then try on ur computer to remove all usb cables and put ur webcam alone and try
Jun 07, 2009 | Logitech QuickCam Fusion Webcam
Instructions state------plug in PS/2 adapter on desktop
You can simply remove the PS2 adapter from the end of the cable to use the USB connector instead.
Remove the green part and use the black USB connector instead.
Apr 09, 2008 | Logitech LX5 Cordless Optical Mouse
Mustek DV5300SE DIGICAM Digital Camera Logo
Top Mustek Cameras Experts
Steven Wander
Steven Wander
Lynnette Kinsman
Ekse
Are you a Mustek Camera Expert? Answer questions, earn points and help others
