Question about NAD T762 Receiver
NAD T762 - no sound
My T762 just stopped producing sound from all speakers for all inputs including the tuner. Test mode which produces snow on all channels is producing sound in all speakers and working fine. Switch to any input on the receiver and I get nothing, no hum, no pop, absolutely no sound at all. Any Ideas?? I'm very interested in knowing if others have experienced issues with the T761 and/or T762. In surfing, I found a company on long island that refuses fixing T761 and T762 as they state they are flawed with many problems. Thanks for your help!
  • Fippi Nov 17, 2007
    "Ditto" - same exact problem. I have not had the unit looked at yet. Do you have any further information?
    Phil
Try reseating the prologic/output board. Second one from the right (from the front of the reciever), that fixed my no sound problems on many channels. You will have to take out a few screws to remove and reseat it, and while you are at it clean the connections.
Posted on Feb 03, 2008
My pioneer av receiver vsx1020 produces same sound in front and back speakers
Try changing surround modes. You might be in 5 channel stereo mode.
Mar 14, 2013 | Audio Players & Recorders
NAD 7140 input selector does not work
The selector chip is not working, either there is no B+ to the ic or the chip has malfunctioned or one of the surrounding components dead, for this type of problem a schematic will be needed to track the problem. try www.nad.com contact customer support and the technical department for additional help.
Jun 15, 2012 | NAD Audio Players & Recorders
Su v8 down on one channel
it would be either:
a) amp or speaker , try to turned off unit, interchange the speaker wire,
the speaker wire on the right channel try to connect it on the left channel,
the right speaker wire to the the left channel .
b) say if the same channel produce weak audio, then the problem is on the SU v8 amp.
c) inside the amp, there are main amp and preamp with selector
switches.
d) try to test , if all inputs , produce the same symptoms.
e) say same symptoms, now try to interchange cables if using
external sources produce the same symptoms.
f) if still have, then inside the unit , it would be either left main amp
or preamp.
g) you can try for a test, connecting direct to "IN" at the back to test
if the main amp is having problem.
Apr 24, 2012 | Audio Players & Recorders
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Apr 19, 2011 | NAD T763 Receiver
All speakers work with dvd but only 2 speakers with tv why is this?
Because the TV is producing Stero L+R (2 spkrs) but the DVD is producing Dolby 5.1 (5 spkrs)
Mar 06, 2011 | Audio Players & Recorders
All speakers work on sound level test but i have no music coming from rear, center and sub when playing 5.1 dvd. also i am unable to use any of the surrond sound modes. richard
What cable did you hook up your dvd? The 5.1 sound works only with optical cable or HDMI. Check in the input settings wich one is selected. With the analog cable ( Stereo RCA) is not working. Good luck!
Jan 29, 2011 | NAD T762 Receiver
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have a phono preamp hooked up to my Yamaha receiver for a turntable. My tall speaker tipped over and knicked the receiver and now my turntable will not produce any sound. Could this have blown the phon...
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Jan 19, 2010 | Audio Players & Recorders
NAD T762 Receiver Logo
615 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
