Question about GE DCSR483EA Electric Dryer
DRUM RUBBING I gave a GE Dryer that has a single belt that secures the drum. THe drum is draging but it appears to be lined up correctly
  • 240 Answers
It could be a number of things to cause drag on the drum. A rear bering or front slides sounds like the most common. The front slides are small plastic like parts that the drum rides on around the door area (GE Part Number GHPWE1M333). The rear bering is located on a stud that protrudes from the center of the rear of the drum. Remove the belt and slide the drum straight out. You will see the bering stud mounted to the drum. The bering will either be on the stud or still inside the bering holder in the rear of the dryer itself. Look for signs of wear or a torn bering. Grease shaft very well when replacing. Also, look for signs of wear inside the dryer to where the drum would be rubbing the case or cabinet. Both these berings are pretty inexpensive and if you have the know-how, easy to replace as well. Good Luck!!!! Jim
Posted on Sep 08, 2007
Have a 2780 dryer stackable that is leaving grease/burn streaks on my clothes. it seems that lower front of drum is not sitting flush. there is a gap against the wall where clothes or dryer sheets get...
you need replace drum support roller,an check to make sure drum hadnt cut into back are the front of dryer the felt that drum roll around on may allso need be replace.some ge dryer have single bear it roll around on it attack to back of the dryer drum
Feb 28, 2018 | GE WSM2780DWW Unitized Spacemaker Washer...
Belt replacement- broken belt on a lde7600acw, older dryer. belt has been replaced but won't line up properly on idle pulley and motor? It appears maybe the tensioner is not set up rigt, maybe the belt...
Remember, the belt DOES NOT sit in the groove of the drum but about an inch from it in the direction of the front.
Also, the belt sits on the drum with the grooves facing away from the drum, not on the drum, a common mistake. If you have a new Genuine Maytag belt then there is a diagram of how the belt fits onto the tension pulley.
Jul 23, 2017 | Maytag Dryers
Drum seems to be rubbing and making noise when turning
the drum does rub ... generally, there is no front or back to a drum. It rides on the rim on the back and on a smaller rim on the door. I normally find a felt "bearing" at these locations. and sometimes, there are wheels at the back on the bottom. Gravity and the drive belt make it work.
I hope this helps you
Sep 23, 2009 | GE DBSR453EBWW Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Ge dryer squeeking
For a pictorial troubleshooting please open the link:
You will be looking at the front glides that the drum rides on, the glides are probably gone and the drum is rubbing on the plastic glide holder....if it is damaged will need to replace the front drum bearing/glide holder and all of the glides, usually about 4 of them.
If it is the drum front glides the noise will be from the front area, right behind the front panel at the top. If the noise is from the center rear of the dryer your drum bearing is gone, need to replace this also if you have to take this dryer apart..
Apr 08, 2009 | GE Dryers
Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Apr 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
GE DCSR483EA Electric Dryer Logo
119 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
