Question about Sony FD Trinitron WEGA KV-20FV300 20" TV
Won't change channel
My television suddenly won't change channels via either the remote or through the buttons on the actual television. any ideas?
  • melissaw Sep 08, 2007
    YOU ARE MY HERO - that worked - although it does revert back again, but perhaps if i do it enough it will be okay. (the other issue is the volume thing which i saw someone else had, where the volume goes all the way up with no way to control it). i was ready to dump it and I've been watching the same channel for a month now!!
    when you say standby mode what do you mean?
    New Friend:
Can not change channels
Posted on Nov 19, 2012
    Genius:
  • 1,153 Answers
Try this in standby mode, press buttons on the remote commander sequentially, in rapid succession: Display, Channel, Sound volume -, Power on
Posted on Sep 08, 2007
  • Lashawn Robinson Sep 09, 2007
    Standby is the tv set plugged in but not on. L.E.D sometimes light up.
    New Friend:
Thank you very much this solution worked for me. Life saver!!
Posted on Sep 03, 2010
SOURCE:
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Toshiba TV
try to open the control and clean it... when you clean it you have to remove the battery, then with some cotton, moist it a bit with alcohol and try to clean all the contacts... after that, let it dry for about 10 mins or more..depends on how wet it is, so dont soak the cotton too much in alcohol.
then put everything back together and i hope it gets fixed..
Dec 13, 2007 | Toshiba 36A43 36" TV
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Guide button won't work on my remote
Either have those buttons checked on another unit or have the remote tested (some digital cameras will react with remote pointed at them)
You need to determine if problem is in remote or the unit.
Mar 25, 2012 | Sony Televison & Video
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-20FV300 20" TV Logo
5,927 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
