Question about Casio Exilim Zoom EX-Z80 Digital Camera
Infinity focus isn't working anymore
About a week ago my infinity focus stopped working. Auto-focus works, as does macro..... when i switch to infinity, the focus frame doesn't appear and the lens stay's in a neutral focus. i've played around with basically every setting, (except for reformatting it), but nothing works.
Ahaha.... never mind. I was dinking around with it again and turns out, infinity focus only works if facial recognition is on... why, i don't know.
Posted on Apr 13, 2009
SOURCE:
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Success
Feb 17, 2014 | Cameras
Auto focus stopped working
Try cleaning the contacts on the camera and the lens, this is what usually prevents AF from working correctly.
Jul 26, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
May 16, 2010 | Rokinon 85mm f14 for Nikon
Auto focus not working Kodak V803
is the setup shoing that it is on MACRO? if so turn MACRO off
Jun 20, 2009 | Kodak V803 Digital Camera
I have a Canon Powershot sd1100, it suddenly stopped focusing.
did you set to Macro, change to Infinity. or goto SETUP MENU, then perform RESET ALL.
Apr 06, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Sigma 70-300 F4-5.6 APO DG MACRO for Nikon AFD Focusing problem
had this lens for my Pentax and used it for more than 10 years without trouble.
Have you got the lock on? should be a little button on the side.
Has it been dropped, maybe damage to the threads inside.
If its still under warranty then take it to the place you bought it from with all its paper work and get it checked out.
Apr 07, 2017 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Camedia C5060 Focus Problem
Hi I have the same focusing problem, the camera was fine until it was switched in to Super Macro, since then the camera will not focus either manually or auto
Jan 18, 2008 | Olympus Camedia C-5060 Wide Zoom Digital...
Unsure of how to use the extra functionality
That is the focusing ring. I'm guessing your camera is set to focus automatically (Little switch on the side of the lens should have settings for either AF or MF, or something similar.)
If its on AF, you don't need to adjust the focus ring.
However, if you have problems with the AF (sometimes it has trouble, especially in low light) you can switch it to MF, and focus manually by changing the ring.
As a general guideline, the more you twist to towards macro, it focuses closer and closer, and infinity futher away (if you're taking a shot of the moon, you want it on infinity)
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Auto+manual focus ranges on the 850Z
The focus information is available at: http://www.ssdonline.com/... ...m?Productid=B111021F&affid=A01&urlid=B111021F
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
161 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
