Question about Targus USB Ultra Mini Keypad Keyboard PAUK10U
My numbers aren't working and my num loc is on
I accidentally held my fingers too long on a key and i got a toggle message (which I didn't read) and just hit cancel. Now my numbers aren't working...the arrow keys are, page up, page down etc. How do I get it back in the numerical keypad mode?
  • 11 more comments
  • tessy130 Dec 25, 2007
    i am having the same problem.the number lock light is on and still my keypad wont work.I even downloaded the disk again and still nothing. can some one help me?
  • redarack Feb 19, 2008
    When I type on my keyboard nothing is happening? Everything is plugged in. What happened?
  • Anonymous Jun 04, 2008
    my numbers and some other buttons still wont work after that same popup about pressing a button multiple times its like its stuck in secondary mode for the keys
  • timyra harri Jun 26, 2008
    my leteer aren't working
  • khalvor Aug 11, 2008
    When I type using the numbers on the keyboard, symbols come up instead of numbers. The entire keyboard seems to be set to choose symbols.
  • carrielwhite Aug 11, 2008
    My keyboard was just installed this am and the arrow keys don't work. What can i do?
  • Anonymous Aug 28, 2008
    i accidently held shift for too long now my numbers aren~t working< how do i fix it?
  • powellb44 Oct 07, 2008
    I guess i held on 2 a key 4 2 long and then i tried playing club penguin on the sled racing,and cart racing and my arrow keys arent working, So what do I do???
  • trishc1985 Nov 22, 2008
    MY LITTLE BOY HED DOWN THE SHIFT BUTTON AND NOEW MY NUMBERS ARENT WORKING PLEASE HELP ME GO BK TO NORMAL
  • Anonymous Dec 27, 2008
    yes
  • Anonymous Jan 05, 2009
    Mine stoped today. I cant Play Jetpack advanture
  • flowergirlma Jan 26, 2009
    i held the shift key too long more than eight seconds and it said something about *Toggle* then i clicked okay now my number keys arent working
    please help me
  • dianne_corle Jan 30, 2009
    I can't type numbers using HP keyboard number pad. I don't have lights to show me NUM LOCK. It just makes two different noises - won't work no matter how many times I press it. I don't have a button that just says Fn. They all have Fn and a number.
    New Friend:
I got it!! hold down the 2 shift keys for a few seconds then bamm!!
Posted on Jun 25, 2010
In Linux (Mint, in my case, which is based on Ubuntu) Preferences, Keyboard Preferences, Mouse Keys, toggle (Off, uncheck) "Allow to control the pointer using the keyboard"
sherbert, new plymouth, nz
Posted on Jan 21, 2009
I just fixed my problem! apparently on my microsoft keyboard, there is a function lock key, F lock, that must be pressed and held as you press your num lock key. i tried it, and i have numbers again! yeah! its been weeks... shhh! =D
Posted on Feb 04, 2009
  • Kathyg
    Kathyg Dec 07, 2013
    THANK YOU !!! it worked for me too :)
I cannot get my num lock to work on my key board. I purchased a new key board and it will not work on the new key board either, I do not have an F lock key.Help!
Kay
Posted on Sep 02, 2009
Had the same problem. Think ive solved this- Try hitting the Scroll Lock button.
I can now type on number pad and the keyboard numbers work ok.
Posted on Dec 02, 2008
It has not been 24 hours yet but i still realy mad because my keyboard is freakin not working well at least the arrow keys arent up,down, side , and side.
Posted on Oct 07, 2008
  • 42 Answers
Hi Is your keyboard light on by that i mean the lights above the number pad on your keyboard some time you may accidently switch of the number lock and this gives you the impression that you numbers do not work just try by pressing the number lock button once and see if this works Hope this helps Paddy
Posted on Sep 08, 2007
  • james ebarb Sep 26, 2011
    i've tried press on & off but still does not work.
SOURCE:
How to print numbers
A manual for such a machine (you don't have a specific model) can be found here (
http://download.dymo.com/dymo/user-guides/LetraTag/LT100H/UG/LT100H_UserGuide_en-US.pdf ) There is a Num Lock key (a padlock outline and '1 2 3' ) on the key. There are keys that have auxiliary numbers beside them. Toggle on the num lock key and then try pressing the key with the number beside it. Should work now :-)
Good Luck!
Nov 11, 2015 | Dymo LetraTAG Thermal Label Printer
Jusy bought a Lenovo Y50. I cant seem to type numbers using the numpad keys (home, page up, etc works when Numlock is toggled). Any advice would be appreciated.
You have to have NUMBERLOCK ON to use the number pad .if you don't want to use the number lock key all the time you can go into the bios and change the setting for numberlock , then your pc will boot with number lock on all the time.
Mar 04, 2015 | Lenovo Y50 15.6" i7 8GB 1TB
How do I get the number lock off
You didn't provide a model # etc. so I'll keep it general. Usually the number lock (NUM LK) is combined with another key, so you need to use the function (FN) key to toggle it on or off. It's usually on the upper right-hand corner of the keyboard, if that helps.
Dec 30, 2011 | Advent Netbook
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
How to use number keyboard
You use the number pad as follows: your index middle and ring finger rest on the 4, 5, and 6 keys. The index finger reaches up or down to use the 7, 4, 1 keys. The middle finger uses the 8, 5, 2 keys. And the ring finger uses the 9, 6, 3 keys. And the thumb is for the 0.
Jun 18, 2011 | Computers & Internet
WHEN I PRESS U I O P J K L ON laptop, it type 4 5 6 - 1 2 3
try pushing the key marks "fn" and "F11" at the same time on your key board.
Feb 28, 2011 | Computers & Internet
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
The keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Regards.
Sep 22, 2009 | Computers & Internet
I HELD A KEY DOWN TOO LONG A MESSAGE SAID TO DO SOMETHING I MISUNDERSTOOD AND PRESSED OK NOW I HAVE TO HOLD EACH KEY DOWN A LONG TIME TO TYPE
I think you have held down the num lock keys for over 5 seconds and have activated the toggle keys, try control panel..ease of access centre ..make the keyboard easier to use..you will be able to do your keyboard settings from there
Sep 06, 2009 | Compaq FS 7550 (Carbon, Silver) 17 in.CRT...
Still cannot get my computer to change from numbers pad to letters on my laptop [email protected]
Your PC appears to be stuck in "Num Lock" mode. Depending on your model, you should be able to toggle this mode with the "Num Lock" key. Once it is out of this mode, the letters keys should work.
May 12, 2008 | Computers & Internet
Targus USB Ultra Mini Keypad Keyboard PAUK10U Logo
6,657 people viewed this question
Top Targus Computers & Internet Experts
J John
Raj Patel
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
