Question about Maytag PAV2300 Top Load Washer
Washer does not spin
My basement flooded three inches and that was enough to cause my washer not to spin, it fill water, but does not spin, is it worth fixing it or should I just buy a new one?
  • 240 Answers
May want to check out the belt on the bottom. If it got wet, it may have stretched it out to wear it wont work. The tension is caused by the motor sliding in and out on a sliding system, which may have gotten a little rust in there. Make sure the motor will move somewhat freely and that the belt isnt stretched to much. Might be an easy fix. Good Luck!!! Jim
Posted on Sep 08, 2007
SOURCE:
What is the probable cause of an LE code?
Most washers give it a certain amount of time to fill up with water and if it doesn't sense it has filled up with enough water after that time it will stop the washer. This is done as a safety so your washer won't flood your house. First thing to check is that the washer is filling up with hot and cold washer correctly, and that the water is coming into the washer at a good rate. The hot water valve has one solenoid, but the cold water has three solenoids (more to go bad). A clogged or failed water valve is the most common thing that we see cause this type of a problem.
Water level drops below the reset level during the wash or rinse portion of the cycle. Check for leaks in the washer tub and connected components. Check the installation of the drain system. Water can siphon out of the washer if it's not installed properly.
Outer tub, Hoses and components attached to the tub
Jun 18, 2015 | LG WM-2277HW Front Load Washer
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
Water fills when machine is off
I would think perhaps you need to call a repair man to have inlet valves replaced .
Sep 05, 2017 | LG WM2240CW Washer
Washer sat in about 4 inches of rainwater water
Do you have friend who would take the time to open the machine.
4 inches might cause a motor short, it is iffy
also when the storm drain backed.. did it trip the circuit breakers that protects your washer
Jul 25, 2010 | GE Washing Machines
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
