I have a dell latitude d600 with no battery power. i unplug the cord and the computer shuts down instantly. on the panel with the battery charge light flashes between orange and yellow. when i press the battery tester button, the lights 1, 3, and 5 light up.
Battery life is only 1 year, after that you will notice that it wont work as perfectly as before. if the system does power on without the ac adapter then battery might need to be replaced.
try to take out the battery from the laptop. plug the ac adapter. if the system works fine with the ac adapter then system is good. try using the battery only then if it wont stay on longer then it is a battery failure.
you can read on about battery life information.try to take out the battery from the laptop. plug the ac adapter. if the system works fine with the ac adapter then system is good. try using the battery only then if it wont stay on longer then it is a battery failure.
Try this, Unplug the power and remove the battery, while the battery and power are unhooked hold the power button down for 30 seconds, Put the battery back in and make sure you slide the locking tap to lock the battery in, try to start the computer, If it doesn't start, plug the power cord in and wait 3 minutes and try to start it, If it still will not start it has an internal issue and needs to be repaired.
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
there is a short circuit onnthe laptop motherboard usually it's power ic's that are next to the power socket that block the power from going to other parts so you should change those ic's
yes there is, go into control panel>power options and choose how long you want the display and computer to stay on for before going on standby.
Turn of the display> change to four hours
Put the computer to sleep>choose never or select a suitable time for when the computer should sleep
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive. Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
I really mean green instead of yellow
