Question about Kenwood VR-506 Receiver
Remote or Reciever?
Hi. My remote appears to stop working randomly, yet even with fresh batteries, and aiming at my computer webcam, i can see the infra-red on the remote sending....it is steady white then off every 2 seconds, then back on..is the remote junk or is my reciever bo longer receiving the signal?
  • blade613 Sep 08, 2007
    Thanks, but i fixed it.
    According to other forums, the IR reciever on the recievers front panel circuit board has cold breaks in the solder.
    You can tell if this is your problem if light tapping on the front panel of the reciever makes the remote control work again.
    I resoldered the three contact points on the recievers front panel IR and it works like a charm.....
    I have a pic of the cold breaks before i resoldered them.....
I had this problem and clearly saw the three solder joints had the telltail rings as indentified by blade613. Resolder them and so far so good. Thanks a million blade613, I had been trying to solve this problem for a year.
Posted on Jul 22, 2010
    Genius:
  • 1,153 Answers
It could be the receiver LED. But I would try cleaning the remote pads first and infrared LED.
Posted on Sep 08, 2007
SOURCE:
How to check my bose rc-9 remote whether its working or not?
Put batteries in it and point it at the electronics unit and press some buttons
Dec 27, 2014 | Bose New Original RC9 Remote Control
Remote for reciever not working
we can check our remote controls the simplest way.. provided you have your cellphone with camera turn it On just like you are to take pictures then aim your remote to the camera press any of the button of the camera then you are suppose to see a light blinking. if there's no light check the battery or replace it with new ones..
Sep 23, 2013 | JBL New Original DCR600 Remote Control
How do i fix my remote
Check it with fresh batteries. If batteries are weak, this might happen. If batteries are good, and still it does not give you distance range, the infrared emitting LED inside it is faulty. To replace it, you have to open the remote control. Check this link. http://electronicshelponline.blogspot.com/ It has details about how to repair a remote control. Pull up older posts. The fault can also be due to a faulty remote sensor inside the TV too. The sensor can be located just behind the infrared sensor window at the front of the TV. Will look somewhat like this.
Infrared LEDs [remote control]
Jun 12, 2013 | Televison & Video
The remote control has simply stopped working! The batteries have been changed! Nothing on the remote is accepted by the TV. There is no response, not even a flicker from the TV.
Try resetting your remote:
* Remove batteries
* Press each button on your remote, twice. (one button at a time). This should discharge any current left in the capacitors.
* Insert fresh batteries.
If the above fails, then your remote is faulty.
Cheers,
Jul 31, 2011 | Hitachi Televison & Video
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
My devices suddenly stopped responding to my remote even though the remote looks to be working normally
Remove batteries, let it sit for a minuit then put in some fresh batteries.
Still not working?
Plug it back into your computer and load Harmony Remote software. Click on "update remote" this will reload the firmware and programming.
I've had a couple harmony remotes go wackey on me but normally re-loading the programming or putting in fresh batteries fixes em right up!
Cheers,
Kevin
Feb 01, 2010 | Logitech Harmony 670 LCD Remote Control
My denon avr588 doesnt work with the remote controller
First lets make sure the remote is in the right mode, in the center of the remote are two slider switches, one on the left and one on the right
make sure the one on the right is in the Audio position and switch on the right should be in the cd position if this does not help check out the link and page 25
http://www.usa.denon.com/AVR-588-OM-E_102.pdf
Feb 08, 2009 | Denon AVR588 Receiver
Remote works but TV does not receive
The IR reciever failure rate on LG tv's is fairly high. A few things to try first.
  1. Clean the IR window on the TV.
  2. Fresh batteries in remote(even though it works other devices)
  3. If you have a universal remote, program it to the tv for testing puposes.
Let me know your findings and we can go from there. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 26, 2009 | LG 42LC2D 42 in. LCD HDTV
I have an Onkyo TX-DS747 and the RC-P101S remote. The functions on the remote worked when we bought it, but when the remote stopped working I was no longer able to use the on screen features and the...
Just a thought, but maybe even the new batteries aren't making good contact (you have replaced the batteries, right?).
Remove the batteries, using a cotton swab and alchohol, clean the contacts in the remote. Then install fresh batteries.
If that does not remedy the problem, you may be able to locate a used remote for your model. Do a google search for remote control resellers, or check a popular auction site.
May 27, 2008 | Onkyo Audio Players & Recorders
Kenwood VR-506 Receiver Logo
286 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
