Question about Hotpoint First Edition WMA20 Front Load Washer
Hotpoint WMA20 First Edition
1. the circuit breakers in the house tripped during mid cycle. My wife said the machine had become "noisy". 2. On turning the machine on again the light on the door indicator began flashing continually 3. The machine would not start. 4. The machine could not be emptied of water but managed to open the door to get the clothes out 5. The door catch (on the machine, not the door) was removed by my wife (don't ask me why) and it fell inside the machine 6. The parts are still under warranty as the machine is only about 2.5 - 3 years old 7. I am not a electrical engineer and therefrore do not know anything aboutt washing machines or their idiosyncrasies.
  • 38 Answers
Your bearings have gone and inturn your drum has droped which has cut heater so it has gone 2 earth which is y your electric has triped the whole job should nt cost more than £120 that is what i charge any way 4 a new inner and outer drum supply and fit good luck
Posted on Sep 08, 2007
SOURCE:
How to replace a fuse in a hotpoint
Check the circuit breaker for the plug the dryer uses. Open your house power panel and locate the breaker for the dryer. It will be 2 breakers connected together by a metal pin so when one trips it will trip the other. This shuts off 240 volts. Sometimes only one breaker will trip without tripping the other one. This leaves the dryer with 115 volts to work the rest of the machine but won't power the heating element. Replacing the breaker will fix the dryer.
Nov 17, 2014 | Hotpoint Dryers
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
I have a Hotpoint WD62 which intermittently trips the house main circuit breaker. Looking at other blogs I am lead to believe it could be the suppressor. Is this likely? And as also suggested elsewhere can...
It really depends upon at what point it trips the breaker. During washing, spinning, drying? If it is during drying don't use that cycle- it could be the dryer heating element. A supressor is normally used on the motor to supress the effect of sparking from the commutator/brushes so I doubt very much that it is that- it would probably trip immediately all the time. It could, however, be the motor itself which is malfunctioning particularly if the tripping happens around spin time. I do think you should call in an engineer, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 07, 2011 | Hotpoint Ultima WD72 Front Load...
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint WMA20 will not fast spin
It is rare that it would be the bearings as there would be play in the tub, it would be noisy and would probably leak. There is a small electrical box in the bottom of the machine. This is the speed control for the motor. You will also find the wireing diagram in a plastic bag in this location. You can check to see which wires require current to activate the different speeds.
I hope this helps.
Dec 28, 2009 | Hotpoint First Edition WMA20 Front Load...
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
GE Hotpoint HTS17GBSERWW
Tripping a circuit breaker (by any device) is an issue that is not easily (safely) addressed on-line. Besides an actual problem with the device in question, one must consider: a) Too many high current devices already on the circuit (toasters, microwaves, washing machines, etc.) that contribute/cause the issue. b) A circuit breaker that trips much more easily than it should (from tripping too much - common problem), and should be replaced.
c) The device in question needs the compressor replaced (very rare in a two-year old device), but can become damaged during shipment - on it's side. d) Damaged sub-component (eg. one of the fans), probably easily found by locating the source of the noise.
Sep 09, 2008 | Avanti FF1101W Top Freezer Refrigerator
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Hotpoint First Edition WMA20 Front Load Washer Logo
173 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
