Question about Toshiba Portege 7140CT Notebook
Toshiba Portege 7140CT battery problem
Most of the time my system won't recognize the presence of the battery. Occasionally the power icon indicates the battery is charging, but after it reaches about 15%, it goes blank and again tells me no battery is present. The battery is new and works on a friend's system. How can I get my system to recognize and charge the battery? Thanks.
  • Anonymous Jun 14, 2008
    I have exactly the same problem with my 7140CT. When the computer "loses" the battery if I shut down and try to restart on the battery it shuts down after a second or so (the HD starts and immediately stops). The battery has to be disconnected and reconnected in order for the computer to function on the battery alone - which it then does no problem. Switching on the power whilst in battery mode restarts the charging - but it shuts off again within 10 minutes at the most. The Windows power meter shows AC Mode when running on the battery alone after restarting when the orange charging light goes off.
    Scholar:
  • 84 Answers
Your ac adapter may be the problem. Is the adapter in good condition. Try using your friends ac adapter since you have the same model laptop. If it charges up your battery and the light stays on your adapter is at fault. Then replace your adapter or the part of it that is at fault. It could be the plug or base. If that does not solve your problem check your dc port on the laptop itself. Shut it down. On the back of your laptop where you plug in the ac adapter there is a pin. Does the pin move? If it does then you have another problem. The port may need replacing which most repair shops don't do. They usually replace the main board which can be costly. Hopefully that's not the problem. Let me know if either of these are not the case then we can go from there. Hope this solves your problem
Posted on Sep 08, 2007
SOURCE:
Toshiba 7140CT laptop only recognizes 65000 kb of new 250gb hdd when started with FDisk
An nice old machine!
If I recall correctly, FDISK low level formats partitions and I don't think the new hard drive will accept it without struggling. The bios on the mother board will not accept a drive as large as 250Gb as they didn't exist when the Bios was made.
Try partitioning as you require and format either FAT16 or FAT32 with another machine and see if it will accept it. I think the Bios was restricted to 6Gb drives so you may need to set up a lot of partitions!
Hope this helps.
Processor
Mobile Intel® Pentium® III processor, 500 MHz, 256 KB 2nd level cache, 100 MHz Front Side Bus Memory
Standard 64 MB SDRAM, expandable to 320 MB Hard disk
6.0 GB1) capacity, S.M.A.R.T. hard disk Internal video modes
1,024 x 768 x 16.7 million colours Display
13.3" (33.8 cm) TFT active matrix colour display Battery
Removable lithium-ion battery, 2-3 hrs battery life, with extra high capacity battery up to 5 hrs Size and Weight
Diskette drive
External: 3.5" 1.44 MB/720 KB
DVD-ROM drive2)
6-speed (max) with optional DVD Network Dock II, 12 cm (5.25") and 8 cm (3.5") disks, data transfer 3,600 KB/sec, average access time: 140 ms
Graphics adaptor
128-bit graphics accelerator, SVGA-/VGA compatible, AGP bus, 64-bit BiTBlT, 4 MB internal Video RAM
External video modes
640 x 480 x 16.7 million colours,
800 x 600 x 16.7 million colours,
1,024 x 768 x 16.7 million colours,
1,280 x 1,024 x 65,536 colours,
1,600 x 1,200 x 65,536 colours
Up to 85 Hz refresh rate
Keyboard
86 keys, 12 function keys, 8 dedicated cursor keys, inlaid numeric keypad, 8 Hot Keys, 2 Windows® keys, AccuPoint™ II, Euro key
Sound System
16-bit stereo Sound Blaster Pro compatible, 3D-wide mode, MIDI & Wavetable synthesis, volume dial, built-in speaker and microphone
BIOS
ACPI (1.0b) enabled BIOS, SM BIOS V. 2.3
Expansion
2 x PC Card Type II or
1 x PC Card Type III,
CardBus support, memory expansion
Communication
Integrated international V.90 modem (56 Kbps data, 14.4 Kbps fax)
Interfaces
FDD connector, external monitor, USB, Fast Infrared Port, RJ 11 modem jack, headphone, external microphone, slot for Kensington Cable Lock
With I/O Adaptor:
serial, parallel, PS/2™ mouse and keyboard
With Docking Station (DVD Network Dock II):
serial, parallel, external monitor, PS/2™ mouse and keyboard, video out (NTSC/PAL), line-in, line-out, integrated FDD, includes built-in Ethernet (Wake-On-LAN and Service Boot support), 6-speed DVD-ROM drive
Power supply
Autosensing 100-240 V AC adaptor for world-wide usage
Casework
Magnesium alloy
Bundled software
Windows® 95 and Windows® 98 selectable installation, Windows® NT 4.0 on request (limited language versions available), PC Card management software, Toshiba utilities and drivers (all preinstalled on the hard disk)
Bundled hardware
External diskette drive, autosensing AC adaptor, I/O adaptor
Special features
Toshiba Hibernation and Resume, Toshiba Power Extensions, System Password Securities, HDD password on request, SecureSleep™, LANDesk Client Manager (LDCM), Wake-On-LAN and Service Boot support (with manageability software and LAN chip), Recovery CD, 3-year international warranty
Options
DVD Network Dock II, carrying case, extra high capacity battery, battery charger, 32, 64, 128 and 256 MB memory modules
Jan 23, 2011 | Toshiba Portege 7140CT Notebook
Toshiba portege s100 without battery
in can work even no battery pack. using your power adapter.
Apr 15, 2010 | Toshiba Portege S100-S1133 Notebook
I installed a new battery and its not lasting for the time remaing. what should my battery be set on normal full power high power saver power
Toshiba usually has a power configuration utility for this... when on battery, reduce your inactive time values to the minimum... suggested ...screen off in 1-2 minutes and harddrive should shut down in 2-5 minutes. system standby in 15 minutes, hibernate in 1 hour.
Apr 11, 2010 | Toshiba Portege 4000 Notebook
TOSHIBA PORTEGE G910 POWER MANAGEMENT problems
try xdadevelopers for this solution,best site for xda pda problems
Mar 23, 2010 | Computers & Internet
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
Oct 13, 2009 | Toshiba Portege M200 Notebook
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
When I turn on the power to the computer it says to press F2 to select boot device. So, I press F2 and nothing happens. So I go to setup and it reads that there is no hard drive, but the hard drive is...
Make sure the HDD is jumpered correctly. You should have a plug and play bios on that board, but you may have to enter the bios setup and go into IDE devices and tell the bios that the HDD is there, or you may need to try a different IDE cable or a different power connector. Also make sure both IDE channels are "on" in the BIOS. Other than that. When the BIOS doesn't detect a HDD it usually means the HDD is dead. More than likely it is something simple that you have just overlooked.
Please be sure to rate this solution
May 08, 2009 | Toshiba Portege 7140CT Notebook
I got the right info about toshiba portege 4000 battery on http://www.adapterlist.com/toshiba/portege-4000.htm toshiba portege 4000 battery but i not sure whether it will fit my notebook or not.
TOSHIBA Portege 4000 Series replacement Notebook Batteries, buy Portege 4000 Series battery and other goods are brand new and one year warranty! ship to most countries http://www.power-tool-battery.com/notebook-battery/toshiba-portege%204000%20series-1001022.htm
Feb 18, 2009 | Toshiba Portege 4000 Notebook
NO POWER ON
Try removing the battery and power cable then holding down the power button for 10 seconds. Reconnect the battery and power cable then press power again to turn on. It's usually a hibernation problem. Some newer toshibas also had a motherboard problem. I'd look up your model on the support section of www.toshiba.com and see if there is an updated motherboard driver install for your make.
Mar 31, 2008 | Toshiba Portege R100 Tablet PC
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
See all Toshiba Portege 7140CT Notebook Questions
Toshiba Portege 7140CT Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
