Question about Motorola Mobility RAZR V3c Cellular Phone
Powers on and off
My wife has lost some calls while on the phone. It will sometimes go to a white screen and somtimes completly go off. We have tried someoneelses battery and the problem to occured.
Known hardware issue. original battery is too small. FIX: battery needs to be pressed onto spring loaded contacts, by squeezing a tooth pick or similar between battery and housing.
Posted on Sep 12, 2007
SOURCE:
Hi, I have a nokia 5220 xpress music,the problem that i been facing from many weeks is that the display becomes white,nothing visible.i m very worried, plz help me what can i do? i think thre is a problem...
is it completely white or its getting white after somtime.....if it is getting white after sometime then it can be software or hardware fault...but if its completely white then I think its ur LCD problem....get it changed
Jun 19, 2011 | Nokia 5220 XpressMusic Cellular Phone
I have lost the ability to recieve or send text messages and check call log
firast remove the sim and memory card then fortmat the phone using this method
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try it your problem was solved
Oct 20, 2010 | Nokia N95 Cellular Phone
Frozen motorla razor phone
most carrier retail stores have cellbrite machines and can retrieve your numbers so long as the phone powers on
Mar 24, 2010 | Motorola Mobility V620 Cellular Phone
Screen problem completely white
what should i do to solve this problem with my phone's screen
Sep 20, 2008 | Samsung SGH-D840 Smartphone
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Screen problems
that mean your screen cable make lose or your screen mobile damage you must change it . when your mobile fill down this problem paper. :-(
Sep 05, 2008 | Motorola Mobility RAZR V3x Cellular Phone
N80 White Screen
white screen?? but still your phone boots fine?can you still receive call or text msg? if soo, your only problem is the lcd of your phone,
but if your phone freeze on white screen and didn't continue to boot up, try reformatting it
by
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
but all your data will lost
Sep 01, 2008 | Nokia N80 Cellular Phone
Nokia N70 phone white screen and Hangout problem
hi there you've go a software problem there try this manual formating somtimes it works but if not must go now to any nearest service center to reprogram your phone. ok!
so here's the tricks to format....
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
ok!
peace!
Mar 31, 2008 | Nokia N70 Cellular Phone
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
Screen went white
Have you tried removing & re-inserting battery and power back on the phone?
Sep 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
