Question about Maytag Performa PAV2200
Maytag performa The timer knob will not turn itself. I put the washer on Normal cycle and it agitate like usual but will not change to rinse. I can manually change it to rinse and it will work. This problem is only on the normal and heavy position. Light position works normally. The delicate side also works fine.
  • 240 Answers
Sounds like you may have a bad timer. They can work perfectly in one setting, and not work at all on an other. They can sometimes get a "flat spot" in one area that will stop them from moving or working. Good Luck!!! Jim
Posted on Sep 08, 2007
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer-LAT7304AAL-about 15 years old. At first it would agitate for a couple of minutes and stop, now has stop agitating. It will progress on through the cycle. I was able to pull the knob to one...
Good day,
If you need to wedge the timer to get a normal cycle, then the timer has gone out. Suggest you replace it along with a new knob, spring and clip. The parts house will point out how to install the knob. Was/is a really good washer.
May 25, 2010 | Maytag Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Maytag Top Load Washer MAV6000
in the console behind the knob is the timer. there are several contacts inside the timer that tell it what to do. one of thoughs contacts is bad. you need to replace the timer to fix the problem
Nov 25, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
