Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso fl error
I am currently draining the machine, but don't know how to remove the front panel to gain acccess to the pump
  • 5,911 Answers
Look along the seam in the front of the washer where the top meets the front panel. About two inches in from each side is a retaining clip. If you take a putty knife and push in on the clip while lifting up on the top, the top of the washer should open up. You may need the assistance of another person and use two putty knives at the same time. It can be a bit tricky sometimes, but the top does open in this manner. Once you have the top open, carefully rest it against the wall behind the washer. There will be a screw holding the front panel on at each top corner. Once you remove the screws, the front panel should come off exposing all the internal components of the washer. You can also remove the back panel for additional access. I hope this helps you.
Posted on Sep 08, 2007
Go to the question above titled "Washer displays FL code" posted on Sept. 28 2007. I just explained how to change a pump and motor from underneath the machine.
Posted on Sep 29, 2007
I have kenmore elite calypso washer. FL shows on the control panel. Some says drain the water manually or check the water pressure. how do I do it?
Probably something in the pump. Remove the base panel take the pump apart get the junk out of it
Older Calypso washers have a pump like this newer ones have a diff type pump that can be taken apart. The FL error : FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for FL to be displayed.
Causes of flood condition. Inlet valves stuck on, Sediment in water level pressure tube. Clogged pump. All of the above. Service manual and more HERE
And HERE
Jul 01, 2011 | Washing Machines
I am getting an FL code on the screen
the fl code on this machine usually means that there is a problem with the drain pump or something to do with the draining process. if you turn your machine up and look on the bottom most calypso units have a access panel that can be removed from bottom requires to remove a few screws ..there is a drain pump on the middle right side of unit ...there is either an obstruction in the pump ,one of the hoses to the pump or the pump has failed itself.... hope this helps you out and good luck....
Jan 06, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The fl code is flashing on the control panel and the machine will not drain. What steps do I need to perform to correct the problem? Thank you
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*%#
Apr 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite calypso washing lights on the front panel will not light up.i push the choice i want then it reads FL and all it does is hum and beep.even when off it will beep and read FL.i will turn it...
Flood Condition:
Oct 15, 2009 | Kenmore Washing Machines
Kenmore Calypso SM9710976A has "FL" on front panel. Whats wrong?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^!!$#
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Calypso washer is saaying LE and FL. what does this mean?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@%^
Jun 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
258 people viewed this question
Dan Webster
Dan Webster
Sal De
