Question about SmartDisk Crossfire Desktop (xf160f) 160 GB Hard Drive
Hardrive not mounting.
Have this partitioned into 3 parts. Only two of them will mount. The other one shows up in utilities but is grayed out. Does anyone know of a way to make this mount. What happened was the computer was not responding and force quit would not work so I resorted to hitting the power button to shut down. External drives should be ejected properly I know but I had no other choice. I have had this problem before and eventually it read the drive again (not sure what I did then other than restart several times). Can anyone help?
  • ckromer Sep 10, 2007
    This is a drive that I have been using for over a year on this computer. I'm using OSX 10.4. If I can't get it too mount I need to find a way to access and remove the data from this drive.
  • 59 Answers
My guess is incompatible file system formats....ex...win95 or win98 cannot see NTFS partitions. just a guess. another possiblity is that logical drive exceeds the size limit that your os can recognize and work with. Good lUck
Posted on Sep 10, 2007
SOURCE:
Help Resizing Mac hard drive with Disk Utility
Boot up your computer with using a linux live-cd/dvd manjaro fedora puppy or other technical distro to start up what will have gparted and or the kde partition manager on it that does do everything unmounted to that will allways enable all necessary things to replace or resize partitions , beware backup first always the distro in any way to be safe with the beginning to experiments. but there are several kind of tools and all open source is free , here you see a part of the kde partition manager and here is to see that will you rezise a partition that it just not must be mounted , thats the most important step to get a working menu by changing partitions that will forget. but it must first are recognized before to choose the right drive partition manager is also good usable for Microsoft or Beos and several other partition cluster arts of other unix systems.
the live dvd will work fully from out the memory of your system thats why it cost many more time for handlings. whats also be better to resize partitions is most time to delete an 3 partition system from the right the third partition (if its handling mounting active partitions to resize up to the right site its differs how to boot with a bootmanager was configured after resizing from the middle partition the find theright cluster out.resize from the left site can made bootproblems, if you not can handle
Apr 27, 2016 | Hard Computers & Internet
Macbook pro os x 10.4.11 won't recognize or mount my new Hitachi xl3000
The Hitachi XL3000 is formatted for the PC, but your Mac should recognize it. Try another cable or port. Check in Disk Utility to see if the drive appears. If it does, then you can format it for the Mac. You can do this in Disk Utility by clicking on the hard drive on the left side of the window. Then choose the Partition Tab, and change the Volume Scheme drop-down menu to 1 Partition. Then click on the Option button, choose GUID partition map, and click OK. Then choose Mac OS Extended (Journaled) for the format and click Apply and OK. Your drive should then format for Mac and mount on the desktop. If it does not appear in Disk Utility after changing the cable and port, or trying another computer, then you may need to return it for replacement. I hope this helps.
Sep 11, 2011 | Hitachi Retail Xl Desk Xl3000 3 Tb...
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
500 GB WD external hard drive not mounting
Just go to the drive icon in the mycomputer and open the drive you can get the files no need to go the utility
Jul 23, 2008 | Computers & Internet
2 out of 3 partitions mounted.
It sounds like you're on a mac. I would run Disk Utility (in your Appications>Utilities folder) select the partition, and click the "Repair Disk" button. If that doesn't work, you may have to purchase a program like "Disk Warrior" (about $100) and that should take care of the problem.
Sep 08, 2007 | SmartDisk Crossfire Desktop (xf160f) 160...
Shrinked
This is the maxtor 4 installation utility: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=MaxBlast_4&vgnextoid=7add8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: MaxBlast 4 is a one-step, ATA/IDE hard drive installation utility. MaxBlast 4 makes hard drive installations and upgrades hassle-free for novices and professionals alike by automatically identifying, partitioning, and formatting any Maxtor ATA or SATA hard drive, making it data-ready in minutes. MaxBlast 4 replaces all previous versions of MaxBlast and MaxBlast Plus. Powermax 4.23: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=PowerMax_4.23&vgnextoid=a37d8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: The PowerMax utility is designed to perform diagnostic read/write verifications on Maxtor and Quantum hard drives. These tests will determine hard drive integrity. The PowerMax utility is effective on all ATA (IDE) hard drives with a capacity greater than or equal to 500 MB. Maxtor recommends the use of this utility for troubleshooting potential hard drive problems. These problems include, but are not limited to the following: * Potential hard drive surface problems (e.g., bad clusters, bad sectors, partitioning/formatting problems, etc.). * Drive recognition problems (e.g. hard drive that is not recognized by the operating system). * Software removal.
Mar 20, 2007 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
SmartDisk Crossfire Desktop (xf160f) 160 GB Hard Drive Logo
67 people viewed this question
Top SmartDisk Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
