Question about Hitachi C3390FSP 33" TV
Problem, i want information about component value because there is burning occered so i want detail about component values of horizontal output section
    Genius:
  • 1,153 Answers
Which component and verify the model number?
Posted on Sep 08, 2007
SOURCE:
Actual value of capacitors causing auto off kolin crt tv
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Aug 22, 2016 | Televison & Video
Why do my TV shuts down?
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.....
Apr 28, 2016 | RCA Televison & Video
Why does my RCA CRT TV not come on? The relay clicks on and soon after clicks off when the power button is pressed.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 21, 2015 | RCA Televison & Video
What's the cause I already install three horizontal output of Samsung TV model number CT-15N30MJ always busted horizontal transistor?
Check the capacitor connected to the collector of the horizontal output transistor to ground for loose solder or open. Replace that freewheeling capacitor [ usually comes between 3900Pf to 9600Pf 2000V]. Replace it with an other one of same capacitance value; before proceed. Even if it blows out the horizontal output transistor; entire circuit should be checked. Check the deflection coil too for shorted winding.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 26, 2015 | Samsung Televison & Video
My tv yoke coil shorted.then i replaced it.old coil number is 6150z9243a.new coil is 6150s.so i cant get full screen in H side.i try to increrse using service menu.but cant.plz tell me the method
You have to adjust the capacitance value of the capacitor connected to yoke. The capacitor bypasses the scan output signal to yoke. It can be located at the main board. Connected to the collector of the horizontal output to deflection yoke. Decreasing its capacitance value will decrease the width of the picture, and increasing will do vice versa.
Refer any circuit diagram to horizontal scan section to locate this capacitor on board.
Apr 10, 2015 | Televison & Video
I have a old crt samsung tv and it kept blowing the horizantal transistor when i replace it wats the problem?
Check the LOT. Check all the related components on circuit board, near to horizontal output transistor, for any loose solder terminals. Re-solder all the suspected solder terminals by applying a little more solder to each terminals. Replace the freewheeling capacitor. This will be a non-electrolytic capacitor, will be connected between ground and collector terminal of the horizontal output transistor. Usually will have a low capacitance value. If all are OK, repalce the LOT. It is shorted. Non repairable part. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Televison & Video
My CTV Philips model 21PT3885/94R shows raster OK but with theband from top to down i.e on vertical but the picture is shifted at right hand side .What could be the pfault or else please let me see the...
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Apr 02, 2017 | Philips Televison & Video
LG 17" 700E CRT MONITOR MOSFET 2N10 IS Immediately BURN OR SHORT WHEN SWITH ON THE MONITOR..
this might be the problem of the disk capacitor of value 2kv, which is located at the horizontal section, i.e from the collector of horizontal output transistor.
Aug 04, 2010 | LG 700M 17" CRT Monitor
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Hitachi C3390FSP 33" TV Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
