Question about Pioneer Premier DEH-P480MP CD Player
Some buttons don't work anymore...
The buttons "Audio", "Fonction", "Down" and "Right" don't work anymore.. I checked the switches with a multimeter and they are OK. I cleaned the contacts between the front panel and the amplifier but the problem was not resolved. Everything is working if I use the remote control, so this is a hardware problem but.. where??? thanks!!!
    Novelist:
    Champion:
  • 219 Answers
If this unit has a "flip face" then I would suspect the ribbon cable that goes from the face to the main circuit board.
Posted on Sep 10, 2007
SOURCE:
Power switch on my T 3042 pc don't work
Check all cables, Try another outlet, are you using a Surge protector/ Backup battery supply? Test the PSU for power output with a multimeter.
Dec 25, 2012 | E-Machines eMachines Desktop PC
Power door switch not working
turn on dome light push button on win switch lights should dim if switch work
Sep 12, 2012 | 1998 Cadillac DeVille
Hi, I have a pioneer DEH-P5500MP which always worked just fine but now when there is no cd in the radio it won't play so i try the source button but that doesn't work so i put a cd in and it starts...
It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
Oct 30, 2011 | Pioneer DEH-P5500MP CD Player
Bought a car with the pioneer deh-p4300 in it and don't know how to set the clock,did not receive the paper work
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done.
May 17, 2011 | Car Audio & Video
I HAVE A OVER HEATING PROBLEM
Assuming you're talking about your amp is overheating, it usually means that you don't have enough room for your ventilation. You can keep it where it is, and wire a couple of computer fans from Radio Shack.You should wire them up so that they turn on with a switch. Another problem is the amp is basically out in the open, speakers could be wired incorrectly. If your amp is stable down to 4 Ohms, and you have them wired down to 2 Ohms your amp can run hot. The way to check this is to hook up a multimeter and see what Ohm load your amp is "seeing." If you don't have access to one, then just simply go to a local audio store and ask them to check that for you.
Apr 16, 2011 | Car Audio & Video
My sony cdx s1000, the source button does not work,therefore i cannot get the radio to tune into any stations.the cd player works but the various buttons have no effect on volume,skip tracks,shuffle etc.
you may have a bad switch. if you can you can use a multimeter to check the resistance of the switches. anything less than a few megaohms, denotes a bad switch usually.
Nov 12, 2010 | Sony CDX-S1000 CD Player
The panel will no longer recognize some of the buttons. for example, the source button doesn't work nor the push-menu. the power and eject button still works. How do i fix this?
it is possible ;you may have a bad switch. if you have a multimeter, try checking all the switches. if one or more is less than a few megaohms, it may be bad.
Aug 12, 2010 | Aiwa CDC-X204 CD Player
Teac cd-x10i
  1. press the standby/on switch off
  2. Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. press the right and left arrows to select. press TIME SET again.
  3. the hour value blinks use the right and left arrows to select the current hour. press TIME SET gain.
  4. The minute value blinks. using the right and left arrows select minutes.
  5. press TIME SET again and the clock starts.
Dec 11, 2007 | Teac MC-DX22I Shelf System
RCA input
its the fonction button on your remote
May 28, 2007 | Sanyo DC-MM5000 CD Shelf System
Pioneer Premier DEH-P480MP CD Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
