Question about iRiver T10 MP3 Player
Unknown device for some reason my iriver is no more recognized after pluging in. in device manager its listed as unknown device. it worked before
  • e3ik
    e3ik Sep 08, 2007
    ok i figured it out. this time one old usb trick for windows xp did work.
    goto device manager
    delete all usb controlers you find there
    restart windows
  • e3ik
    e3ik Sep 09, 2007
    see upper post
4 Suggested Answers
SOURCE: iriver T20 not recognized
download this software and do a recovery - helped me !
http://www.iriver.com/support/down_view.asp?idx=736
Posted on Jul 24, 2008
SOURCE: iRiver Music Manger not recognizing iRiver player when connected
Next time when you connect your IFP-795 and your computer recognizes the new hardware, let the Wizard install it (even though you have already done this previously). You should not need the install disc anymore as the necessary files were previously installed on your hard drive. This worked for me, hope it does for you as well.
Posted on Feb 09, 2009
SOURCE: I brought a new computer
Reformat your mp3 player ..you can use the hp format tool ..click here to download the program.
After you downloaded the hp tool,install it,and launch the application.
Posted on Jan 31, 2011
Just bought an iriver S100 GB mp3 player but computer doesn't recognise it. I've tried using device manager and usb settings but still no joy.
Go to settings, Advanced, Click Rebuild Database. Also make sure you are uploading songs through iRiver Plus 4
Sep 23, 2010 | iRiver X20 MP3 Player
Transcend pendrive
you just uninstall that unkown device which you get in device manager and reconnect the pendrive if again it says unknown device then goto update driver and select 2nd option which is advanced in that select don't search for driver i'll select and select the driver which is shown in the list and click next and finish ur pendrive will works
Jul 08, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Externals not recognized by computer.
Go to your control panel open up 'administrative tools' Open Computer management, then choose disc management instead of device manager. Make sure that you have the drives pluged in and connected before you do that. All connected drives formatted or not that are in working order should show up under disc management. If they are not showing up they are not compatable. Make sure that they are marked as active and format them if they need to be formatted. Do so by right clicking on the drive in the disc management window.
May 12, 2009 | Hitachi External 20GB Mini Slim Hard Drive...
My mp3player isn't recognized by my computer.
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
H
May 07, 2009 | iRiver T30 MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
Vista will not recognize iRiver H10 MP3 player
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Jan 08, 2009 | iRiver H10 MP3 Player
I plugged my Memorex TravelDrive into my computer. It has always worked perfectly. This time I got the message that the USB device was not recognized and I can't get into my files.
THE FOLLOWING IS COURTESY OF MICROSOFT Help and Support
When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
Unrecognized device has been found.
This issue occurs because, when the computer comes out of S3 or S4, there is a five- to ten-second period when the selective suspend feature of the USB driver will interfere with detection of a new USB device connection. The time period depends on several factors. This includes the following factors:• Host controller hardware
• Attached hubs
• Attached devices
• USB driver versions
• Support for USB 2.0
• Additional system hardware or configurations that may change the timing
There may be other reasons that a USB device is not detected
Method 1
loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2
After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 3
Use the Device Manager to scan for new hardware. Follow these steps: 1. Click Start, click Run, type Devmgmt.msc, and then click OK..
2. On the Action menu, click Scan for hardware changes. This causes Windows to recognize new devices.
3. Close Device Manager and Control Panel.
Method 4
Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK.
2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties.
b. Click the Power Management tab.
c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
SIMILAR PROBLEMS AND SOLUTIONS loadTOCNode(1, 'moreinformation'); For more information about advanced troubleshooting tips for general USB problems, click the following article number to view the article in the Microsoft Knowledge Base: 310575 (http://support.microsoft.com/kb/310575/) Advanced troubleshooting tips for general USB problems in Windows XP For more information about how to troubleshoot unknown devices in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 314464 (http://support.microsoft.com/kb/314464/) How to troubleshoot unknown devices that are listed in Device Manager in Windows XP
Try restarting the computer with the device in. Sometimes if you clear the memory that might help (stating the machine without memory then put it back and start it again).
Jul 01, 2008 | Computers & Internet
SEAGATE FREEAGENT DESKTOP 500GB READS AS UNKNOWN DEVICE
Try this metho for xp,
rightclick ''my computer">>propties>>hardware TAB>>device manager>>You will see a list>>at the top off the list (without other option above) you will see computer icon with your PC name>> rightclick that>>scan for devices (the hard drive should pluged ) >> go on >>.need more help?
Mar 06, 2008 | Computers & Internet
Iriver T 20 not recognized.
All the answers/drivers/manuals for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Dec 28, 2007 | iRiver T20 MP3 Player
iRiver T10 MP3 Player Logo
101 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
