SOURCE: Headlight
I think u can replace it by 220's headlight and any bajaj authorised service center can do this job but just to tell u that the 220's headlight works out well in terms of design because it goes well with the fairing on the tank. If u try to put it on 150 then probably it would not go with the tank of 150 in terms of flowlines and it will also look big and bulky.Do remember that the headlight assembly unit of 220 have a different wiring mechanism as the headlight comes with a Xenon projected lamps. U will have to change the wiring system of your 150 by 220's one and will cost u big bucks. But if money is not a constraint for u then u can always go ahead and do this job on your bike.
SOURCE: Gearbox not smooth in Pulsar 180
Because its one gear front and four as back so it doesnt smooth..
SOURCE: i have a problem with my bajaj pulsar shock absorber, within three months it was found hard
i think it is shock absorber.after 15000 km it is recommended to change the oil of shocker.
1>you may topup your shocker oil then see if their is change or not.
if not
2>then your shocker must be tilted or damaged which can be repaired with a pressure machine or they must be changed....
SOURCE: shock absorber of bajaj pulsar 150 is touching
hi buddy can you tihgten the springs on the shock as the shock doesnt support the weight it just balances the up and down forces
