Question about Hitachi 50UX57B 50" Rear Projection Television
50UX26B Convergence or Ghosting problem
My Hitachi 50UX26B has convergence or ghosting problems, three years ago I fixed it @ a shop and now it came back again. I want to know if there are any circuit boards that are sold as 1 piece instead of replacing some IC's, resistors and other components ..The teck needs $380 to fix it which in my opinion is too high to fix an old TV. but if the price of a complete circuit board is reasonable since they are almost obselete then i would be interested in buying a board and replacing it myself. Please let me know if the board is available , where can I get it and how much do I expect to pay for such a spare part. Thank you
    Sergeant:
    Champion:
  • 375 Answers
New convergence pc board is worth $400-600 /repair the old because you probably won't find one and if you do the same thing will happen in time anyway,you know what you got and must ask your self .what will it cost to replace it at this time /shop around /compare prices and extended warranties////////////
Posted on Sep 08, 2007
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Ghosting and bad color, sound is fine.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Convergence
*Screen Looks 3-D
*Colors wont align
Problem #2
Aug 20, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 50ux57b
The green and blue ghosting is a convergence problem that is either bad connections at the convergence ICs or defective ICs. If you can solder, try resoldering the ICs. If that fails to resolve the problem, replace them. These ICs are large black ICs attached to a heatsink. They should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Hitachi 50UX58B 50" Rear Projection...
Color ghosting
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 11, 2007 | Hitachi 50GX30B 50". Rear Projection...
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Misaligned Convergence
Is anenvolved job to repair a convergence problem,the way to go about it is to locate the convergence amplifier IC's,one for each color(red green,blue)check for loose conections at the ic's legs,after resoldering all the legs see if an improvement is present if it gets better you will be able to adjust from the custumer controls,but if no improvement the Ic's will have to be replaced.Some units have a separete board were you can adjust convergence after replacing the Ic's and other units you have to access the service menu to be able to do the adjustments but just doing this adjustments can be very challeging even for a train technician,I would suggest you seek assistance from a servicer and get an estimate.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50UX57B 50" Rear Projection Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
