Question about Frigidaire GLTF2940ES Front Load Washer
Water does not enter
No matter what cycle the washer is turned to water will not enter. I have checked out all the common problems:water pressure levels etc. I've had the washer for a year now and it use to wash fine but now whenever I choose a cycle it turns on normally but no water enters. Both the hot and cold water are completely turned on, there are no kinks in the hose and no known clogging. I believe one of the hose has a small leak to the tip of it could that be the problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
PLease check the water inlet filter. This is normally located just where the cold water hose connects up to the machine
Posted on Sep 08, 2007
SOURCE:
Frigidaire front load washer starts the cycle but no water enters the washer
Hello friend, I appreciate your post!
Based off the information you have provided water is not entering your Frigidaire washer. Are the house valves turned on fully? Check to make sure that the house valves are turned on and if they are check to make sure the water hoses are not kinked or pinched.
The problem could be within your water pressure, pressure switch, or water inlet valve. I would recommend reaching out to a professional for further assistance regarding your washer to avoid any unnecessary part purchases. I hope this has been beneficial. -Matt
Oct 12, 2014 | Frigidaire Washing Machines
Washer error on rinse cycle
E11 means the Fill time is too long. There are a whole bunch of tests to perform - but the easiest is to replace the hoses going into the machine - I had the same problem and tested my hoses - they looked fine - but my machine would do this every so often - turns out my hoses had "check valves" that were a safety design to prevent freeflowing incase one burst.....well the valve was going bad. Replaced both hoses - never had a problem again. But anyways... here are the other tests...
1. Is the incoming water flow normal?
Yes. Go to step (4). No. Go to step (2)
2. Are the incoming water faucets turned completely on?
No. Turn water faucets on. Yes. Go to step (3).
3. Is the incoming water pressure above (30) psi.
No. Have customer correct pressure problem.
Yes. Check for kinked or blocked incoming water hoses, clean
the incoming water screens. If problem still remains, replace the
water inlet valve assembly.
4. Does the fill water continue enter the washer?
Yes. Go to step (5). No. Go to step (6)
5. Remove power from the washer. Did the water fill
stop?
Yes. Go to step (6) No. Replace the inlet valve assembly.
6. Good models, check the pressure switch.
Pressure switch checks good. Go to step (8).
Pressure switch checks bad. Replace pressure switch.
7. Better models, replace the pressure sensor.
If this did not correct the problem, go to step 8.
8. Replace the control board.
Good Luck!!!
GOOD LUCK!!!!
Apr 05, 2014 | Frigidaire ATF6000ES Front Load Washer
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
We have no rinse cycle?
The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is:
If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Thank you
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
FH has shown up on my whirlpool duet washer GH9150, water was shut off and now it is stuck in cycle and will not stop
FH = (No water detected entering machine or pressure switch trip not detected)
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
Replace failed component.(Which will be the pressure switch if all checks out ok, above)
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer model: GHW9200LQ 1-2 minutes into the washing cycle washer shows error code HF.....there is water in the washer.....checked faucets....checked hose for leaks..I had to use the spin...
I found this in when I looked it up.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. - or -
Verify CCU operati
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
142 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
