Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony Trinitron 32" TV
There are three places in the back of the TV to hook up to cable and I have tried all three. What is puzzling is I can plug the TV in and turn the power button and nothing happens. Why?
Switch the antena button on the remote
Posted on Dec 13, 2007
SOURCE:
I have a xbox 360 slim and I am trying to hook up to a sony trinatron wega model # KV27FS120
you will need to purchase the the xbox A/V component cables as your tv doesn't have hdmi
Jul 14, 2014 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Trying to hook up Phillips DVD player and have 3 coaxial cables that need to be hooked into Sony TV and I have 14 holes for cables-help!
Don't use co-axial cables buy HQ SCART Gold Plated Ribbon cables with full 21pins then hook up the AV out of the DVD player into one of the AV in on the TV.
When you turn your player on it will autoselect the correct AV (audio visual) channel on the TV.
Feb 12, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 32 in sony trinitron and i do not know
You need a matching transformer, or 'balun'.
Any home electronics store will have these. $3-$5.
Now, if this TV does not have a cable connector on the back, there is a good chance you will not be able to receive many of the channels (not a cable-ready TV).
Jan 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron has stopped working mid viewing. The on/off/stand by light just flashes. Any idea how to get the TV back on?
You can try unplugging the TV power chord, leave unplugged for several hours, then plug back in and try it.
If no results you will need it serviced as there are many possibilities. If the light is blinking in a pattern, example flashes three times then pauses then flashes three times again, the number of times it is blinking can give the servicor a clue as to what circuit is at fault.
Oct 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Connecting DVD/VCR to TV
I called Sony and they guided me through it and all works fine now TY
Mar 19, 2009 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Sony trinitron XBR2 32 " can't seem to get the cable working on it
You can hook up to either aux or vhf not converter. then with remote use ant button to select the one you are connected to. then do the auto search. Also can you get to 3 by pushing 3 and ent on the remote?
May 18, 2008 | Televison & Video
Sony Trinitron Tv
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Oct 31, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
