Question about Dell E151FP 15" Flat Panel LCD Monitor
Dell 151fp is slow to get going, fine otherwise
5 1/2 year old Dell 151fp works fine once it gets going. The problem is that it takes 5-10 minutes to "warm up" after being turned on.Thescreen remains blank during this time. It sometimes seems to help if you click the mouse or press a key on the keyboard. I hooked up my new Dell 1707fp and it worked fine. I called Geek Squad and they said they've never heard of that problem, I should buy a new one. It also takes several minutes to get going if left on when the computer is turned off.
  • 30 Answers
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Posted on Sep 09, 2007
SOURCE:
Our LG takes a while to turn on....is there someway to fix this?
replace bulging capacitor at power supply board the it will resume to normal operation.
Jul 21, 2012 | LG Televison & Video
05 cts when iturn the key the engine does not stat just a click 2 or 3 times the it starts and it does not sound healthy( im from winnipeg minus 25 don't plug car in) when it warms up it does strt fine...
If it's the original battery, it's 12 years old and way beyond it's useful life. If replaced once, the second battery is probably near the end of its life, five to six years
If you're near a Wal-Mart super store, get a new battery installed if the other is old, five to six years They have good prices and top rated batteries by CR. While you're there and if it's -25 (C or F since the scales are concurrent about that point) go to snack shop and warm up with a nice hot cocoa or hot cup of coffee. Sometimes its free in the customer lounge.
Good Luck
Sep 22, 2017 | 2005 Cadillac CTS
Monitor works for a few minutes, then flashes gray
Replace the bad capacitors in the power supply. They are usually visually detectable (tops bulged). The ones that usually good bad in that model are 1000mfd. 16v.
Dec 08, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Projection television acting like an old picture tube TV.
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Sep 16, 2009 | Toshiba 43H72 43" Rear Projection...
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Dell laptop gets hot quickly
Get some compressed air from Radio Shack or other place that sells it (unless you have a small compressor) and blow out the laptop. My laptop gets dusty very quickly since I live in the desert and I blow it out at least once a week to keep it from overheating. You will be amazed at how much dust will come out. Let me know if this helps.
May 23, 2008 | Dell Latitude D600 Notebook
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Dell E151FP 15" Flat Panel LCD Monitor Logo
329 people viewed this question
Ekse
Clive
Clive
