Question about Black & Decker Compact Power Screwdriver
Black decker drill
Drill won't tighten around bit
  • 313 Answers
Go to any service center they will help you out to much the chuck. dont's really matter what brand as long it fits
Posted on May 29, 2008
If the problem is with very small bits 1/16" for example, the chuck could be defective in either design or manufacture. I have had this problem with a cordless model FS1800D. Waiting on a replacement chuck.
Posted on Sep 18, 2007
Tighten a bit in
Hi if the picture is correct this driver only takes 1/4 inch hex bits & will not hold a round drill bit
Jan 20, 2014 | Black & Decker Pivot Plus Cordless...
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
Chuck is stuck , can't get it unlock to tighten around a new bit
Could be a dying battery making it not be able to open itself cuz theres not enough juice, try charging the battery and do it or get some wd-40 and spray it around the chuck and let it drip over the bit into it.
May 18, 2011 | Black & Decker Pivot Plus Cordless...
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
Insretion sdrill bit
Loosen drill chuck, insert flat end into chuck and tighten.....go drill some holes!
Jul 10, 2009 | Black & Decker & Swivel Cordless Drill
Black & Decker Quattro, drill, won't tighten to grip drill bit.
give a good coating of oil then clamp chuck in a bench vice or alike and using short bursts with it set in the forward direction to free the chuck
Jul 07, 2009 | Hand Tools
Black and Decker KD950K drill - how to insert drill bit
most keyless chucks have a button on top that you push in near the chuck it locks so you can tighten or undo
May 27, 2009 | Drills
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
May 24, 2009 | Black & Decker Drills
Black & Decker Compact Power Screwdriver Logo
218 people viewed this question
Top Black & Decker Hand Tools Experts
Robert Monigold
Robert Monigold
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
