Question about BenQ M310 Wireless Mini Optical Mouse
Problem pairing wireless mouse to reciever
Hi, I recently purchased a G Max Wireless mouse. I am unable to pair the mouse with its receiver. When I connect the receiver to the USB, then i hear a sound that a laptop makes upon a new h/w being connected. Please help...
  • deadskull May 10, 2009
    Please help...
HI ALL, Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is the process of coordinating your mouse's transmitter with your mouse's receiver. It requires both parts to operate on the same frequencies, usually by using the same identification code. Pairing takes place to try to eliminate interference. Some devices automatically pair both devices at start up; others need to be manually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteries in mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) and place the batteries. Cover, Now you can see the red light glowing on the bottom of the mouse, now your mouse is ready to pairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE will be ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, if mouse curser is not moving then press BUTTON 2 one time – now defiantly your mouse will work, If you need any other technical support for GMAX, products please contact
Posted on Apr 13, 2010
  • SATISH RAJPUT
    SATISH RAJPUT Apr 13, 2010
    please note all models of GMAX wireless optical mouse are DRIVERLESS, so there is no need to install any driver,
No it is not the problem with drivers as you get the drivers installed in the OS on you plug in. I am sure of it because even I have the same problem. I have 2 OSes Windows and Linux and the maouse was working properly. If it was a driver problem it should have worked in one OS atleast. But its not working in both. So if anyone know a solution please help.
Posted on Oct 20, 2008
My wireless mouse recievier broke can my mouse work with some random USB ??
Posted on Aug 21, 2009
    Problem Solver:
  • 18 Answers
Problem suggests that your system requires a driver software. Try loading the driver and restart the computer for checking the function of your mouse.Else go through the system help and support from the start menu for further checking the function of the mouse.
Posted on Sep 10, 2007
SOURCE:
Are all wireless computor mice plug and play?
Wireless mice have two parts, the mouse and the transceiver paired with the mouse. As a pair they are plug and play across computers. You cannot use any mouse with any transceiver. They are a pair.
Hope this helps.
Sep 18, 2018 | Computers & Internet
Wireless mouse is not working
Hi and Welcome to Fixya
Change the batter first and try to pair the computer and wireless mosue again. Push the connect button underneath the mouse while on the process of pairing.
Thank you and have a good one!
Jan 22, 2011 | Acer Aspire One Netbook 8.9" Notebook
I moved my computer to another room and after the move the mouse worked but the keyboard doesn't. Tried everything I could think of but to no avail, It was a Micro Innovations wireless mouse and keyboard
Have you tried pairing them??? Press the button on the transceiver til the light flashes and then in turn press the mouse pair button followed by the keyboard pairing button. See if this fixes it
Hope this helps
Mark
Aug 24, 2009 | Micro Innovations Wireless Optical Travel...
Usb Trouble
The USB ports all share a single power source. It may be that the Ipod being added overloads the connections.
You might want to consider purchasing a USB hub, but make sure you get one with a Power Adapter to boost the current to your devices.
Oct 01, 2008 | Microsoft Wireless Laser Desktop 4000...
Windows vista wireless mouse stopped working
have you tried replacing the batteries in the mouse or is the reciever needed to pair up them both again by means of a little button in the underside of the reciever
Sep 07, 2008 | Computers & Internet
How do you install a wireless mouse
you have to install the software driver for the mouse, then connect the reciever to a usb port, then the reciever will be recognised and instal the driver automatically.
There should be a pairing button on the reciever and the mouse tt set it up, after that it should work ok
Sep 04, 2008 | Computers & Internet
I recently bought a Compaq Wireless Desktop w/Optical Mouse (Gry/Sil) at a yard sale and did not recieve the instalition cd where can i download the program at online so i can use it on my computer
As long as you have the wireless reciever and the mouse, and a fresh pair of batteries theres no reason why it should not work. Its simply a plug and play device.
In fact, I wouldnt be surprised at all if Logitech manufactures their mice for Compaq and sticks the Compaq name on it instead.
Aug 16, 2008 | Computers & Internet
UNABLE TO PAIR MY BLUETOOTH
Try to hold the volume command on - and + both It will recognize the device when searching for bluetooth headset.
Feb 15, 2007 | Sony Ericsson Akono HBH-608 Wireless...
BenQ M310 Wireless Mini Optical Mouse Logo
3,585 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
