Question about Sony Cyber-shot DSC-S600 Digital Camera
Sony cyber-shot 600 digital camra
Hi i have a problem with my camera when i turn it on theres a black screen and it tells me to switch power on and then of i've been trying to do that but its not helping so i don't know what to do please help me. regardes vesna
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Can you play back stored images ? if yes and picture quality is normal but no picture in capture mode then it is CCD sensor fault and it has to be replaced. If you have no image in playback either then you might be lucky and it is the LCD screen. Lucky because repair is cheaper.
Posted on Sep 09, 2007
SOURCE:
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
I have a Sanyo Xacti camera and i stopped working. When i turn on the power button, the red light comes on and thats it. the screen won't work but you can tell the camera is trying to work. I've...
hi, your camera problem isn't clear but sound like shutter unit does not initializing. I don't think you can save. It is not simple job for if the shutter problem then local repair shop would charge you $65 to 135 mostly. good luck with you
May 21, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
If the issue persists, service may be required.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Black screen...
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Sep 10, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
LCD screen went black
No. It is likely that there is still water in it. It's very important that you take the battery out and do not try to use it. Take it to a repair shop and be SURE to tell them it had water in it so they can take the appropriate steps to clean and protect it.
Aug 04, 2008 | Sony DSC-T7 Digital Camera
Canon power shot A70
Hello Dear,
This is a problem with the Camera CCD unit, u r requested to carry the Camera to the Canon Care Centre and your job will be done free of cost.
Wram Regards,
Manoj Joseph
+91 9352008418
Jun 13, 2008 | Canon PowerShot A75 Digital Camera
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
