Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
Digi 002 rack
Have a Digi 002 rack that has just developed a problem. When I turn it on I here switching internally the read out just has a bunch of dots I am unable to restore operation by turning off the unit and turing it back on or unplugging.
  • 2 more comments
  • Whittman Mar 12, 2008
    My 002 is doing the same thing. I have had the unit for 2 years. It used to do it once in a while, but now it won't boot up at all. Once every 50 times I reset it, it will start properly and then in the middle of a session it will crash and the mute button light remains on. I noticed the optical light on the rear panel flashes on and off with the clicking as well as the Firewire link light. I also made the mistake of upgrading to OSX 10.4.11 and cannot install the previous combo update. Regardless, I have Panther on another partition and the 002 still wont work.
    Any help would be great Thanks
    Ryan W
  • bdues Feb 20, 2009
    Same problem.  I had the problem about a year ago and tried everything I knew. I had pretty much given up, and click, click, click one of the green sample rate lights lit up and it was fine.  Last weekend, again when powering up just the red mute light; no green sample light. (There are three to indicate sample rate but only one should be on at a time.)  I have tried to restarting and letting it rest to fix itself but no luck.  I am dead in the water.   I can't find anywhere how to do a factory reset.  Anyone know this?
  • Anonymous Apr 22, 2009
    same as. so frustrating
  • kendallcombe May 15, 2009
    same issue just happened to me, I've used this for 5 or 6 years now why all of a sudden. anyone find anything out?
Easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Posted on Oct 19, 2009
  • 3 Answers
U guys try new firewire cord had same problem
Posted on Jan 14, 2010
  • 382 Answers
Ive heard the 002 have a latent click after hitting the power button. There was a known fault recognized by digidesign, if the unit is under warranty, call digidesign for support.
Keep me posted.
Posted on Nov 06, 2007
My Digi 002 Rack is "Clicking" (the actual unit).
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
How do i clean the dc power? what is that?
I think you're referring to a problem that's known with Digi 002 Rack where the power harness oxidizes and loses power connection over time.
Digi used to send you a new power harness & contact cleaner to make sure that doesn't happen again. You should contact their customer service if you're having an issue with it.
May 27, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
My ProTools LE Digi 002 rack stopped connecting to my IMac.
clean the ribbon cable connection on the dc power harness with contact cleaner. i had the same problem. this fixed it.
Feb 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Which firewire cable do I use with my Digi 002 console?
If you are using a desktop comupter, you will need any 6-pin to 6-pin connection. If you are using a laptop, you will need any 6-pin to 4-pin connection.
Jan 12, 2009 | Digidesign Digi 002 Rack FireWire Pro...
Broken Digi 002 firewire port
Did you solve this problem yet. If not let me know im looking for a 002 to do some testing plus i need some spare parts.
Dec 19, 2008 | Digidesign Digi 002 Rack FireWire Pro...
Macbook pro does not detect digi 002 rack
yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Dec 04, 2008 | Computers & Internet
Digi design 002 rack
Is your firewire cable good? Sorry, I know this is obvious.
May 08, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
"Unable to locate" 002 Rack Unit - sometimes!
Please help this guy and me too. I had the same problem. I emailed digidesign but cant get a good answer. I hpe this shit is not broken. I just bought it 2 years ago.
Sep 10, 2006 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
3,357 people viewed this question
Top Digi Computers & Internet Experts
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
