Our HP Officejet 5610 All-in-one printer recently started having some lines that are not printing properly. Thinking it was running out of ink, I replaced the (black) cartridge. Even still when it prints the test page, the blue seems to be allright, but the bottom of the page (black) seems like it's only printing every other line and very faintly. My husband even uninstalled and reinstalled it, cleaned the cartridge and it's still not working. Any suggestions? The 1 year warranty is up on it and I really don't want to get stuck buying another!
Have you recently changed your cartridges? Try replacing them, if you haven't printed for a while the cartridges will dry up and you will not be able to print.
did you try the copier function?if you can copy documents then the scanner is good,well if it wont works you cant print neither..but as you said you get a print out.reinstall it carefully and slowly..the logic board has no problem,just focus on the driver..
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
just click here....
just click here....
The cartridges may need to be cleaned by the printer. Check for this option on your user's manual, they will usually refer to it as a nozzle check/clean.
If the cartridge is clogged and does not unclog replace the ink cartridge. Contrary to what people might think these cartridges have a shell life and can be faulty out of the box.
clean the printer roller, and the prin head.
go to hp.com, support and troubleshing and type in the model number. Get the user manual adn follow the direction.
Does it happen while printing from all the applications or from only any particular appication or from e-mail/web printing ?
Click Start (Windows Icon) - Printers Folder
Right click on the printer icon Officejet 5600 series and select properties. Click on the Advanced Tab. Enable the option Print Directly to printer. click Apply and OK. Check for the result.
