Question about Acer Aspire 3610 Notebook
Pc card slot
On my laptop i pressed the eject button for card slot and now it wont click back in i was just seein whut it was and now i cannot get it back in
  • blayzie Sep 08, 2007
    i was just tryin to see whut it was there is a filler in it yes but when i ut the filler back in the eject button wont go back in all he way
    i dont have anything to put in it but the filler only and the button always pout now but before it was clicked in, it wont bend down though i have a acer aspire 3680 i was just pressin the button to see whut it would do i dont have a card to go in just the filler but it wont go back correctly and the button stays out now i understand its early here too thanks lol
I had the same problem and I just literally 30 seconds ago fixed it. What you do is take the filler card out completly. Then push the button in until it clicks and then you can put the filler back in and its good as new!
Posted on Sep 16, 2007
    Scholar:
  • 181 Answers
There are a couple of different kinds of these; one kind simply folds over when not used. THe other kind should push all the way in till it clicks (sort of). Was there a filler piece in the slot to begin with? Good luck
Posted on Sep 08, 2007
  • jim walenciak
    jim walenciak Sep 08, 2007
    Some are like this: when a card, (or filler piece) is inserted, the button slides out. If that's the case, look to see if there is a way to bend the button down so its out of the way.
    Otherwise, is the button all the way in before installing the filler piece? If so,and it comes out as you install the filler, then most certainly it bends over out of the way.
    With the filler out, can you push the button in so it stays in? If so, does it come out when the filler is inserted?
    Confusing I know. Sorry, it's early here.
    Good luck
SOURCE:
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
How to insert the cd inside cdrom?
The slot will be there in the left hand side of the computer.. It will look like a slot rather than a tray so please use that.. In order to take a disk out of the computer floow these steps
Normally the studio laptops have soft eject for the CD and they dont have a button.. Press and hold the Fn key and then press the F10 key to eject the cd.. Another way is get into computer.. Right click on the DVD/cd rom drive and click on eject... This will work....
Dec 06, 2010 | Dell Studio 1737 Laptop
Dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
May 24, 2010 | Dell Vostro 1510 Laptop
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
I have a Asus K60ij laptop and I cannot eject my
If when you press the card in to eject it, it doesn't come out, you can use a pair of tweesers to gently pull the card out. There are no mechinisims holding it in place.
Nov 22, 2009 | ASUS A6U Notebook
I have hopefully just burned my first photo CD but am unable to get the disc out of the slot. I have pressed just the eject button but don't know what else to do - and yes I AM blonde!
Hi, LOL!!
Ok, if you can't eject the disk double right click on computer, where you see you CD/DVD drive right click on the icon and select eject from the list.
If it still won't eject get yourself a large paper clip and straighten it, look very closely at the eject button on the CD/DVD drive, you will see a very small hole. Push the straightened paper clip inside that hole and manually eject the disk.
Post back if you need anymore help.
Good luck.
Aug 20, 2009 | Dell Studio 15 Laptop
The nexlink CL51 has a small button that you depress to eject a plastic card. How do you keep the button from sticking out?
After you eject the PCMCIA card you can push the button in until it clicks and stays in. Now you insert your PCMCIA card into the slot and if you want to eject the card you push the button and it will pop out then press the button to eject the card.
If this pressing the button in doesn't lock the button in place, then the spring catch on the button is broken.
Jul 08, 2009 | Computers & Internet
Disc stick in console
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-106
May 16, 2009 | Nintendo Wii Console
Can not remove sd card from storage expansion slot
Push the card in just a bit until it clicks, then it should release unless it is stuck. Sometimes this happens with new SD cards until they are inserted and ejected a few times.
Mar 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
On the left side of the machine i pushed a button and a small pa
That is the PCMCIA eject button. With no card in the PCMCIA slot (Slot empty) you should be able to push the button in slowly till it clicks, then release and the button should stay in. Then re-insert the blank filler or card you had in the slot. (To engage the retention detent, you have to press the button in slightly past the outside of the chassis)
If the button will not engage the detent, then the motherboard will need to be replaced to fix it (The button is part of the motherboard)
Mar 01, 2009 | Dell Inspiron 2200 Notebook
Acer Aspire 3610 Notebook Logo
66 people viewed this question
Ekse
Alun Cox
