Question about Dryers
Dryer will turn/spin but it will NOT dry with hot air at all. It is a Whirpool WED5200TQ Dryer.
  • Dryers Master
  • 8,220 Answers
Unplug it and remove the rear cover. Check for lint in the pipes. Take the heating element off and look for broken coils. Mounted on the heater is a cupla safetys. The small one at the top is usually open IF the element turns out to be ok. This phenom is caused by a blocked dryer vent.Dryer will turn/spin but it will NOT dry with hot  - f7a9c3e.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 10, 2009
    Problem Solver:
  • 17 Answers
Check blockage in your vent pipe
SOURCE:
Drier dries too slowly. it does heat up but i always have to turn on again for 40 more minutes to complete drying. it does get hot. and i am not overloading.
You do not state if you are using a machine with an automatic drying sensor. If so the calibration of the sensor is off. Try setting the control to a dryer setting. If you are using it by time only, it would appear there may be a blockage in the air outlet. Check the damper flapper at the output of the air vent. It might be partially stuck closed thus reducing the air flow around the clothes. Just a thought that your washer spin dry may not be sufficiently spin drying the clothes and so that the clothes are overly wet when put into the dryer..
Oct 05, 2011 | Estate TEDS840JQ Electric Dryer
For past 6 months dryer has been making a noise while drying and when I turn it off sounds like it is still spinning for a second. Now dryer is making a squealing noise as well and not drying the clothes...
Sounds like the blower wheel (fan ) is loose on the motor shaft.... that is the spinning you are hearing...
but the fan/blower is not running full speed so it is not moving enough air...
heatman101
Jan 18, 2011 | GE DBXR463EDWW Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
Does nor dry cloths
Most likely the thermal switch near the heating coils is bad. This switch regulates the temperature of the air in the heating coil section, and when they go bad, they usually get stuck open. Do a continuity test across this switch (disconnected). If good, check the switch on the motor - this switch enables functioning of the heating coils only if the motor is actually turning (safety). Good luck.
Nov 28, 2009 | Whirlpool Dryers
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
My whirpool dryer does not dry. Drum works fine. No hot air
The following link will give you some helpful advice on a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. Clogged, or poor, ventilation is the number one cause of dryer heating circuit failures. Inspect the ventilation and internal blower fan housing BEFORE replacing any defective components. Failure to do so may result in premature failure of the same components.
I hope you find this information helpful. If you require additional assistance, please let me know.
Nov 29, 2008 | Whirlpool Dryers
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
