Question about Pioneer VSX-D608 Receiver
Overload? Hi, I recently get an "OVERLOAD" blinking message for a few seconds and than the receiver shuts down. Any ides what the problem is? Thanks, Eran
  • erans Oct 06, 2007
    I found the problem shortly after my post.
    One of the speakers cord was disconnected and shorted. The problem disappeared once I reconnected the speaker.
I was recently on the Pioneer site researching this receiver. They just happen to have a few suggestions for trouble shooting this particular problem. I think you have to have cookies enabled to view this link. Hope it helps ya.,,2076_310069579,00.html
Posted on Oct 05, 2007
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
Have recently had an "overload" displayed. Have
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
When I turn my television on it auto turn off after a few seconds. The light starts to blink when I first turn the tv on and then the Tv just shuts off on its own.
Hello Sir, hi, you have power supply problems, this is caused by a bad part on the main board or on the power supply board to overload, when overload happens, the power supply immediately shuts down to prevent further damage. my first advice is call your dealer for proper service.
Dec 07, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
JVC RX-7030V - Overload - Protection
the transtistors are mounted to a large heat sink. and yes all 4 main trany's need replaced. you can go to the library and look in sams photofact for the service manual. the part #ers are on the transistors. have fun and good luck again.
Mar 09, 2010 | JVC RX-7030V Receiver
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
May 23, 2008 | Technics SA-DX930 Receiver
Any hdmi channels i turn on cause an overload message on the receiver and it shuts down. How do i fix this
Check the surround setting you may have these HDMI channels set on. Try changing the audio setting to STEREO to see if you still get the OVERLOAD message. If it helps you may have faulty wiring on your surround speakers. This would explain why it was only happening on your HDMI settings.
After checking your wiring and not finding any problems you will have to narrow it down to the source of the problem. Disconnect your center channel and retry the surround mode and see if you get the OVERLOAD.
Once you find the problematic speaker you may need to replace it. Unfortunately it could be possible the speakers are unable to handle the power being provided by the receiver and may be sending feedback to the unit causing it to overload.
Mar 15, 2008 | Pioneer Audio Players & Recorders
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Technics SA-DX940
overload, usually means that is overloaded. i've had the receiver for about 4 or 5 years now and never had problems with it. It was sitting ontop on my tv for those 4 or 5 years, and i haver noticed it untill just recently, (when i bought a new tv and i had to get a stand for it, and i had to stick the receiver in it)that is runs very hot, very quickly; Maybe that is the problem you are having now, that the thins is older and maight be able to handle it as it id b4. Maybe you made some changes to your set up: new speakers, etc.
Jan 25, 2007 | Technics SA-DX940
Check your wires for cross polarity
Dec 20, 2006 | Technics SA-DX940
Pioneer VSX-D608 Receiver Logo
258 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
