Question about JVC HX-D77 Shelf System
Subwoofer??? When I hooked up my system and hooked it all up, I noticed that only one of the subwoofer holes is releasing air? Is that normal? What can I do?
    Problem Solver:
  • 15 Answers
Switch it around connect the right side to the left output and connect the left side to teh right input and see if the same speaker isn't pushing air if it still isn't pushing air then you have a few damaged speakers. If it starts to push air on the side that didn't then it could be a dead output.
Posted on Jun 24, 2008
  • 3 Answers
I have the same stereo system. The JVC HX-D77 has 4 air ducts (GIGA TUBES). The lower two are very active air ducts. The upper two are more passive but they still move air. If only one of the subwoofer air ducts is moving air you may have big problems because one subwoofer channel drives the subwoofer and the woofer above the subwoofer. If it was the left channel air duct that is not working both air ducts on that channel should not work and both air ducts on the right channel should work. If only one side is not working check the wireing make sure that both wire ends are in perfect condition. If they are this may indicate one side of your subwoofer amplifier may be fried. If you actually only have one air duct working that would indicate that you would have three faulty speakers. (Highly unlikely) I would recomend that you unplug your JVC HX-D77, remove both speakers (Main and subwoofer) check all of the wires. If they are fine hook your speakers back up and plug the unit in. If the problem still persists contact JVC.
Posted on Oct 08, 2007
You should double check the wiring.
Posted on Oct 03, 2007
SOURCE:
How do you power up the sattelite speakers without the subwoofer?
Depends on the type of sound system. Some require you to hook up to the subwoofer then the subwoofer to the sound system, others are just a direct line in to the sound system (in which case simply un hook the sub woofer. If it requires hook ups to the woofer, see if you can turn the volume down on the woofer directly.
May 29, 2015 | Audio Players & Recorders
How to hook up a subwoofer?
On the back on this model, you will notice a REAR OUT Connection. A powered subwoofer can be directly connected or amp can be connected to this to connect your SUBWOOFER
Jul 26, 2014 | JVC KWAV60BT
No sound from subwoofer
If your subwoofer does not work on your altec lansing speakers,
more than likely you blew the subwoofer amplifier board.
I have an ADA-885 system and bought it brand new back in
November 2000 and has been flawlessly operating great up
until this past month when my subwoofer went out but my
"satellite" speakers kept working. After disassembling the
subwoofer box I first noticed that the subwoofer amplifier
board is seperate from the rest of the grouped boards for
the dolby and satellite speakers. The subwoofer box is
designed to use the air from the subwoofer to actually
cool the amplifier boards inside the unit, great feature
until your subwoofer goes out, that is when your main
amp will more than likely fail soon after the sub amp
fails, as it uses the air from the subwoofer to keep the
amps cool. I know this might be an older post but
hopefully I can put it in the right category to hopefully
be able to help someone out in the future.
You can test the ohms of the speaker with a multi
tester. It's a dual voice coil speaker, 6 ohms each.
Well my system is broke and needs another
subwoofer amplifier board so if anybody reads
this and has this subwoofer, I need my sub amp
fixed ! or if you have the subwoofer unit maybe
and nothing else to go with it but the subwoofer
lights up, give me a jingle, I'd buy it from you !!
Jul 23, 2011 | Altec Lansing ADA 885 Computer Speakers
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
My subwoofer started smoking-
a usual problem of a subwoofer just like my old sound system. Subwoofer generates a big heat on its device unlike ordinary speakers. better to send that to a technician to change a spare parts. it must be an ic problem got damage by over using.
thank you for using fixya
CHARCOIS
Nov 02, 2008 | Altec Lansing 641 Computer Speakers
Subwoofer interferance
Sounds like you've got a floating ground wire on your wall outlet, or you're plugging the sub into a different circuit from the receiver.
Make sure your sub and receiver are plugged in to the same circuit (ideally, the same outlet) and if you still have the problem then you need an electrician to test/fix your ground wiring.
Nov 30, 2007 | KLH ASW10-120 Subwoofer
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
Subwoofer hums under power not hooked to system & hooked up?
This may or may not apply to your particular problem. On similar humming sound problems, I normally would look for either a fault in the input side and/or a leaky/defective capacitor in the power supply. On the input side, this may be a frayed shielded wire, loose connector (esp. the outer which is normally the ground). Try completely removing the connecting/input cable that goes into the subwoofer. If that doesn't work, then it you may want to check the big capacitor in the power supply section of the subwoofer. If you are not that familiar in working with power supplies, may I suggest that you ask any electronic technician to have a look at it since capacitors store a rather hefty voltage. Better be on the safe side. Hope this works out ok with you
Mar 11, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Blinking Led power light
I have a alpine MRP-M350 700 watts class D... i will ask if it can support 2 subwoofer a 1200 watts 10" JBL subwoofer?
Aug 22, 2006 | Alpine MRP-M350 Car Audio Amplifier
JVC HX-D77 Shelf System Logo
204 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
