Question about Hoover HDC6 Electric Dryer
Dryer stuck in sensing mode
Stuck in sensing mode - will not get beyond, will not heat, will not tumble
  • 6 more comments
  • trnondalight Dec 15, 2007
    My dryer will run & heat for only 15 seconds then stops, repairman
    says it is the control board. I called Amana since it is only 1 yr. old
    they will pay for the part, but it will take 6 days to get the part and install.
    Where did you get the part so quickly?
    Can my husband install this if we can get the part?
  • slusherkitty Feb 06, 2008
    I have a whirlpool dryer about 9 years old . was working fine until the other day it got stuck in the cool down stage and ran all night and didnt shut offf. Now when i try to use the dryer it wont heat up. It is model number ler4634eq2 type# 12200 ..Please help
    Kelly
  • Anonymous Feb 21, 2008
    I have a brand new HE2 gas dryer that will power up, but won't start drying. We have a service call in, but no one can come out for two days. We've unplugged it and let the timer run all the way down. We still have nothing.
  • valley32 Mar 12, 2008
    I have a FER231 dryer and it stays on for 3 sec and turns off.
  • Anonymous May 10, 2008
    I have a GEW9250PW1 Front Load whirlpool electric dryer~ Tried to turn on this morning, sounded like a click in control panel to left of dryer but only sensing button came on. I unplugged, turned off breaker and tried to turn back on. No luck. Vaccumed out dryer vent area and filter , no luck.
    Still just clicks like it is trying to engage but nothing else. Please help/gadreams@gmail.com
  • jeannerose May 13, 2008
    Dryer stuck in sensing mode.... will not tumble.
  • bobvenn Jun 14, 2008
    3 Month old Whirlpool electric Cabrio dryer stuck in sensing mode. The dryer will not operate.
    I have cut power, and cleaned 2 element sensor inside drum. So far nothing has cleared "sensing" from from display. Unit still under warranty, but I cannot wait several days for repir. Does anyone have any suggerstions?
    Thanks,
    Bob Venn
  • jandogomez Dec 24, 2008
    I've got the same issue with the 4 month old electric dryer. No service available for 9 days...
Ensure machine is disconnected from the mains supply.
Check thermostats, under rear cover. They should be closed. If in doubt, bridge them one at a time, then try the machine.
Bear
Posted on May 27, 2009
Hello
i have a hoover mega load condencer dryer HNC 375 T
after switching on the filter sensor light flashes
cleaned all filters but still the same
can anyone help
Posted on Jan 19, 2009
Since no help was available without premium assistance, I actually contacted a repairman. He performed all the tests again and told me the problem was the control board. Then wanted $600 to fix. I found the part online for $150 and fixed it myself in about an hour. Instructions were easy.
Posted on Sep 28, 2007
White Knight C86AW electronic sensing tumble dryer Too Hot
Probably a defective high temperature sensor
Jun 08, 2018 | Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Dryer turns on but does not tumble, sensing light is on. The last of laundry was incredibly hot. If it's the thermal fuse, wouldn't the dryer still tumble, though?
Not Tumbling means that the belt has slipped or broken, the over heating could indicate that the motor is burned out and the fan that moves the air is not working.
Jan 19, 2016 | Dryers
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
Tranmission wont shift
Gears inside welded together, or stuck in limp home mode. Is it stuck in a gear other than 1st or reverse? Limp home mode will select one gear, usually 2nd, when computer senses a problem with valve body pressure, or excessive heat. Either way it sounds like a trip to the ****** shop.
Oct 06, 2012 | 1999 Plymouth Voyager
My dryer turns on and reads sensing , but does not turn ....does heat
If your dryer heats yet does not tumble i would be looking for a broken belt..when its heating that means the motor is running,but since i suspect the belt of being broken its not tumbling
Sep 13, 2011 | Whirlpool WED8300S Dryer
Duet dryer on sensing mode>what does that mean
The "Sensing Mode" occurs when the dryer is trying to detecting the dampness of the clothes in the dryer to determine if they are dry or not.
If the dryer is "stuck" in sensing mode - there is a problem that should be checked.
Sep 06, 2011 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
The timed dry cycle sometimes does not turn off;
If it continues running beyond the cycle point it probably is no longer producing heat and just tumbling. Eventually there is a heat sensor that is triggered. Mine does the same thing. It is likely the result of the timer going bad, though immediaely not a necessity to fix, in the long haul it will save you utilities.
Dec 07, 2009 | Frigidaire FSE748GF Dryer
Hoover HDC6 Electric Dryer Logo
1,197 people viewed this question
Top Hoover Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Archie Ferrarini
Archie Ferrarini
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
