Question about Akai LCT3201AD 32 in. LCD Television
Dvd not ejecting
Dvd is not ejecting when open button is pressed. I get little grinding noise. all other dvd functions works fine.
    Genius:
  • 1,139 Answers
You may have some stripped teeth on the DVD load/unload motor gear, or some place withing the DVD gear train. If you can take the unit to a qualified TV repair shop for investigation.
Posted on Sep 08, 2007
The dvd player will not eject the disc
Try powering off from the mains completely for a minute.
Does it try to eject it at all ?
Any noise when the eject button is pressed.
Are you getting any messages on the display.
Feb 05, 2011 | Samsung DVD-VR330 VCR and DVD Recorder
I tried to eject a DVD and now the DVD holder is
if you had forced it open its probably not aligned (if its still open give it a little shove and press the eject again (otherwise unplug the machine for 5-10 min..and try pressing the eject button again
Jul 09, 2010 | Toshiba D-VR4 DVD Recorder/VCR
How do you retrieve a DVD that will not eject? When we use the eject button, we hear a grinding noise. Can we open up the DVD exchanger to retrieve the DVD?
1st. turn off dvd and tv
2nd there is a small hole in the front of the dvd case,,usually close to the eject button.
3rd use a straight ,,slowly insert and you should feel a lever that will open the door. i,portant to so this slowly...
May 28, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
2006 Toyota Sienna with an ADVENT DVD
Well, if its crammed in there from kids shoving stuff in there as kids will tend to do sometimes, then i am sorry to say, you most likely will need to get a new player. Cause general when something is jammed into disc slot, other components that are vital to operation have been compromised. But on the other hand. If it was working and operating fine one minute, and the next it simply just wouldn't eject. Your problem is one of the 2. Is the player making any noise as if it is trying to eject the disc but will not, and can you still at least play the disc and watch it since its already in there? If so. It sounds like you have a bad gear or a little spring that has popped that engages the gear to make the mechanism for disc ejection impossible. Or the main drive belt has dried and broke. Take it to a local tech. 2nd. If its not making any noise when eject button is pressed. The button itself might be bad. Try the remote controls eject button. If it has one, that might eject the disc. Hope this helps. And in tghe future, no paper clip tricks okay. Only damage can occure with that method. good luck,
Apr 26, 2010 | Televison & Video
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
DVD tray won't open
Try to reinitialize the DVD functions, in the manual:
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
Page 84
Turn the player OFF,
Press and hold the power button, While holding it, press the Stop button for 2 seconds or more.
Once its reset, see if it will eject.
Dec 27, 2008 | JVC DR-MV1SU DVD Recorder/VCR
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
Akai LCT3201AD 32 in. LCD Television Logo
77 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
