Question about GE WBXR3100B Top Load Washer
GE WBXR106074WW The unit will not work in the was cycles, only if the timer is manually moved to spin it works
  • 725 Answers
Sounds like you have a bad timer. if you can get it to spin manually..LEt me know if you replace it.. Thanks Krazytech
Posted on Sep 08, 2007
SOURCE:
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
GE washer not spine
First thing you can due is to manually move the time to drain and spin mode. This will check your timer to see if your timer is working. If it start working then it is your timer. It will be your timer gone bad.
Dec 05, 2009 | GE Washing Machines
I have a kenmore washer model # 110.20722990 will agitate but will not move to the next cycle to drain or spin
If you can manually move the timer to spin and it works replace the timer. If you move to spin and it does not work, replace the lid switch.
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
GE Washing machine not cycling
"...can hear the electrical contacts trying to hit". The timer may be defective.
Oct 05, 2017 | GE Washing Machines
GE WBXR3100B Top Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
