How do i connect my samsung sound bar so that the sound of the tv comes through the sound bars speakers, ie sky, playstation etc.
Try going into menu,setup then audio setup in that order on cable box to activate different features on the audio. If you are wanting to run optical you may have to get it activated thru comcast. The optical is not always active.
If you can't play your TV through the Sound-bar, what is the point
Not sure for the playstation etc, but for the TV the manual says using the (not included) optical link between TV and the main unit.
Note that this is not mentionned in all language versions of the manual.
Just checked the manual:
For playstations devices and the likes, use (not provided) cinch cables (they are red and white) if your playstation has a cinch audio out (the audio out connectors are usually red and white too).
If it doesn't, use a cable that is cinch (red - white) on one side, and a matching headphone jack for your device on the other end.
Anyway theThe cinch goes into AUDIO IN 2 on the back side of your main SAMSUNG unit. See p22 of the manual.
If your device has not optical out, no cinch audio out and no headphones jack, you cannot hook it up to the SAMSUNG.
instructions to connect
