Question about Bosch SHV4803 Dishwasher
Dishwash cycle takes too long.
The dishwash regular cycle is 280 minutes. It used to only take 86 minutes. I tried running the hot water before turning on the dishwasher, but it did not reduce the time.
  • 209 Answers
I am a recently retired appliance engineer of 20 years no that won't help, dishwashers only use one pipe cold water, check fill pipe for kink or low water flow rate filling up,if no problems then check heater element for open circuit, then check for any blockage with water outlet / filters and pump etc well somewhere to start to be going on with, if any of above helped rate me please,
Posted on Sep 09, 2007
SOURCE:
Dishwash cycle takes too long (7mins) and dishes are extremely hot
The heated dry may be turned on. You can shorten the cycle by turning it off.
Apr 30, 2016 | Dishwashers
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
Nov 30, 2014 | Baumatic Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
TAKES A LONG TIME,
Takes a long time to what? If the entire cycle seems to take forever, one suggestion is to make sure your hot water heater is turned up. Most dishwashers requires the water to be a minimum of 120 degrees before the timer will begin. If you are using a Sani-Wash cycle, then the water need to heat up to 165 degrees. The heater can only heat the water 1 degree per minute, so if the water coming in to the dishwasher is only 100 degrees, it will take an additional 65 minutes before it will even start the cycle. You can also make sure you get the water at the sink hot before you start the dishwasher, this will ensure the hottest water is going in (only fills for 90 seconds).
Jul 30, 2010 | KitchenAid KUDR01TJ Dishwasher
The dishwash is not washing, it's running but there is no water. The washing cycle is completed but nothing has happen, this recently started.
Sounds like a bad water valve or the water supply is cut off. If the water supply is not cut off then try hooking up 120 volts to the water valve. It should buzz or hum and let water in. If no water goes in then change the valve.
May 15, 2010 | Dishwashers
What is the amount of time for a regular wash? Time on the plus wash?
a regular wash should take about an hour and a half. plus wash would be longer only because it heats the wash temp hotter.
wash temp is generally around 140 degrees
and your rinse is around 161 degrees.
your flow through heat assembly heats the water at 2 degrees a minute. so it can take anywhere from and hour and a half to two hours for a full cycle.
try turning your sink on hot water until you feel hot water coming out then start the dishwasher so it doesnt have to heat cold water up to those temps. it should run a little shorter.
Feb 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes crack when washing and also the time does not set less then 1hr19min.
if dishes are dishwash safe then the water heater is on too hot. if that hot water can hard boil an egg then its too hot.for the time try unplugging it for a minute and plug it back in. that should reset wash options.
Nov 09, 2008 | Dishwashers
I have a Bosch SHV55M03GB dishwasher which does not heat the water. The programme cycle also sticks at the last minute. Any ideas, heater element or control panel? Thanks.
If cycle proceed normally after waiting for a while, then the control is probably OK. It stands by a while because it does not read correct temperature before proceeding.
If the appliance is connected to both hot and cold water, open more the hot water faucet.
If the water is not heating at all, check heating element for continuity, using a tester.
If water is heating regularly, but cycle is still slow, check thermic sensor.
Here are more suggestions from Repairclinic:
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
If you need replacement parts or exploded views you find them here.
Oct 10, 2008 | Dishwashers
Whirlpool Dishwasher Problem
the dishwasher will probably heat the water the rest of the way for you. depending on the specs and features.
hot water is not likely an issue with the dishwasher itself.
you could have cold water plumbed to the unit by mistake.
also, it could be that it is not fully pumping out, and the water going in is mixing with water in the sump.
try running it for few minutes and then pump it out. start a new cycle and see if you are getting hot water. if not, then at try to confirm that the unit is heating the water on its own. run it for about half a cycle and check the water temp again.
you do need hot water to clean in most units.
for certain this is a plumbing problem that is delivering cold water. and if its not heating, make sure that it should be per manufacturers specs, and call for repairs if its not heating the water.
good luck
mark
Dec 20, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch SHV4803 Dishwasher Logo
217 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
