Question about Hotpoint WMA50 Front Load Washer
Water pumping out of draw and trickiling out of door
Every time we do any cycle from 40c to 60c water squirts out of the conditioner draw. And a little from the loading door itself. Had this happen before and i cured it by taking off the waste pipe and cleaning out all the lime scale and gunk but this time it didn't work. Any ideas?
  • olwyn Aug 02, 2008
    water is coming from the dispencer drawer and also from the door when machine goes to rinse and spin i tryed checking the drain hose in case of a blockage but it was all right then i removed drawer put a hose pipe to the drawer drain and flushed water through it went well but there was alot of gurgling but nothing came back out until i went and started another wash after draining the machine it went all ok until rinse and spin and out came the water again how can i stop this happening
  • 725 Answers
If it does it when it fulls. You may have something stuck in the fill hose blocking the water inlet..be sure to unplug the washer then Remove the top.. Then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me know if this is it... krazytech
Posted on Sep 08, 2007
Is machine meant to flick to 60c wash on any cycle
Sounds iffy to me and 60'C would damage woollens. Buy a waterproof dishwasher thermometer. They have a maximum and minimum setting so you can find what you washing machine temperature actually is. Sounds like it need a new logic board.
May 05, 2016 | Washing Machines
Loud humming/buzzing sound when the washing cycle starts. It does it only with cycles with hot water from above 60C and above.
hi
I suggest that if the machine does have a hot fill intake that you connect this because this will insure long life to the electric element you will be saving money as you already have hot water and this might rectify the problem
Jan 28, 2018 | Washing Machines
I can not get the water temp to above 180F and the local health inspector realy want it to have the minimum of 71 degree celcius or 180F.If I leave the machine idle the temperature gauge show 72C but as...
Hello Huekycanada
You have to check the booster element what amp they are drawing there are three elements if only two are working it will still goes up to 72C may be it need longer time to get there. Secondly I would check the in coming water from your hot water tank it should be 60C at the machine , To check this incoming water temperature the best way is checking the temp. at the sink nearest to the dishwasher. 9 out of 10 I do find this is the main cause of the problem ( the in coming water temp is too low)
All the best, Dickson
Apr 22, 2011 | Moyer Diebel 24 in. 501HT Built-in...
My B70 just starts running water through and doesn't stop till it's drained the reservoir...Any clues?
I have taken the beast apart and watched it successfully cycle and fail to cycle.
Warning!!! (DO NOT TRY DIS-ASSEMBLY IT UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING AND RECOGNIZE THE COMPONENTS, You could electrocute yourself and suffer nasty permanent scaring... ouchie!)
I discovered the same as another person claimed a "check value" and/or air leak/lockup. The pump cycles, but can't get water so the machine shuts down to prevent over-heating. (The dreaded "Not Ready").
Solution...
1. Turn off the machine and unplug until it is completely cooled, say 4 hours. (Allows for temperature equalization of the water chamber and the water supply)
2. Completely fill the water reservoir. (The extra water just helps the pump break the air lock).
3. Turn the machine on and wait for the pump to start drawing water.
4. Immediately knock 1-3 times on top of the water reservoir/machine (at the very top of the machine) about as hard as would knocking on a door. (Watch the water level, it should immediately start to drop)
The pitch of the pump should change when the water begins to be drawn into the heating chamber. (you can also hear the water flowing)
The problem is caused by air entering the water supply system. This air provides a "lock" on the system that the pump can't overcome. This can happen due to a number of issues but most issues should be this easy fix.
The machine refills itself 3 times. At Power-on, at beginning of the brew cycle and after the brew cycle.
Watch the machine and any time the pump cycles make sure it draws in water until it shuts down, if it doesn
Dec 08, 2010 | Keurig Platinum B70 Coffee Maker
My WP EA6800XTW0 is leaking onto the floor. Why?
You are the best judge to see the exact spot of the leak.
So use your palm to moe over to find the water trickiling.
Look around the door gaskets , the drain hose, the drain pump or a spillover from the inlet hose/inlet valve.
In all these cases a good plumbing job can help to plug the leak. If however within the valve or pump , remove and try repairing with resetting or replace.
Sep 16, 2010 | Whirlpool LSQ9560PW
Bosch SHE45M Odor? What can I do
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean. Do this on a regular basis.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Add 1/4 cup (60 mL) of liquid chlorine bleach to tthe machine. DO NOT use more than 1/4 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C) if you have one or use a 60C wash. DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure as necessary.
Sep 30, 2009 | Bosch Dishwashers
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Hygena Dishwasher
I would check for blockage, can you hear the pump trying to drain.
pull all the metal pieces ouy and have a look.
Jul 27, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Won't take Fabric Softener
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2007 | Zanussi FJS1225W Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
85 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
