Likely there's a size limit to the USB memory stick. It doesn't say in the 200E manual but a search on "usb stick" on the Janome site would indicate some earlier USB capable machines may have a 2GB limit.
Your carburetor is the issue. You have to adjust the H needle on the carburetor. You adjust this by turning in quarter increments while holding the throttle in... if there are plastic limiters on the ends of the adjustment needles u can take them off... they are there for epa regulations only... also go to you tube to get a video on how this is done, good luck,u can do it!!
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
