SOURCE: oil dip stick
Had the same problem last year - the plastic handle broke off and the
top of the remaining plastic was visible down the tube but was stuck
solid. Finally used an easy-out to get it out. Drilled a small hole
into the plastic and then threaded a thin easy-out bit into the hole
and it held enough for me to pull the dipstick out. Stupid design, a
plastic handle on a metal dipstick!
Here in Canada the Intrepid is badged as a Chrysler. Sounds a bit dodgey to me :-)
SOURCE: oil problem
Somehow that crankcase is being pressureized. You say the pcv is not blocked, but I would replace and check again. The next step is quite expensive and I would want to rule out that pcv for the 10 bucks that it might cost.
SOURCE: oil spraying out from the oil pressure switch
Oil pressure switch is bad. Consider a replacement fast before you loose your engine.
SOURCE: 2007 tucson 2wd 4 cyl.oil leaking - starter is
get it fixed. then get the shop to clean off the starter. oil is not good for electrical parts.
