Question about HP Officejet J5780 All-In-One InkJet Printer
PRINT ERROR MY PRINTER SHOOTS OUT PAPER WHEN I TRY TO PRINT ANYTHING. I HAVE A NEW IMAC
  • ToddESmith Feb 24, 2008
    I have downloaded the Mac drivers for this printer twice, yet when I print anything, it shoots out one sheet of paper with some meaningless (to me) text at the top, and then keeps shooting out blank sheets of paper until I hit cancel print...any ideas on how to fix this?
Page not dectect
Posted on Apr 07, 2008
Just had a paper jam , removed paper and now when i try to print, it just shoots blank paper. Help?
try to print anything from your pc if its working that means you have something wrong with scan unit,but if its blank too make sure that your copier has toner and get yourself a new drum unit.
Mar 10, 2016 | Canon MG2920 Wireless Printer Scanner
Media tray empty
Printer is not sensing the papers.Try and re-load the papers a few times
Apr 24, 2014 | Brother Office Equipment & Supplies
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Paper jammed but sheet came out with corner shredded...assume piece(s) stuck in printer but cannot see it...followed manual's trouble-shooting guide but printer will not print...keeps showing error code...
If you aren't willing to disassemble the printer, and you are unable to see the missing pieces of paper, you will need to have the unit serviced or buy a new one.
If it's under warranty, don't say anything about the shredded paper, just tell them that it started with this error code one day, and you have no clue what's wrong.
Feb 26, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Cannot empty the print que print jobs on IMac status is Deleted, except for last line which says "printing", but it is not printing
This is most likely because an error with the printer is making it impossible to delete the final print job. The most common error is no paper or a paper jam. Look for blinking lights on the printer and any error messages. Feed more paper if necessary. Once you fix the problem, reset the printer or press the blinking button.
Feb 21, 2010 | Dymo LabelWriter Thermal Printer
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Printer won't print anything.
Try to uninstall the drivers and turn off the printer. Then install the drivers back on and turn the printer back on. And then make sure this printer is set as default.
Mar 27, 2009 | Canon Pixma MP480 All-In-One InkJet...
Cannon MP460 will feed paper through printer but not print
Check your printer sharing in the system preferences... make sure it's on.. then when you get the print window, look for your printer under shared printers... try it that way... worked for me on my wifi network here.
Mar 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
HP Officejet 7130 xi all in one say Bad Print Head
printer flashes lightes and instructs to turn off and on. When ask to print
Apr 06, 2008 | HP Officejet 7130 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
27 people viewed this question
Clive
Clive
