Question about Canon DR-9080C Path-Through Scanner
Error P00 My scanner gives a P00 error indicatinf a paper jam. There is no jam. It may be bad sensor. Any ideas on how to fix or who can repair.
    Sergeant:
  • 279 Answers
A few easy things to try. First off, have you power cycled the unit since checking for a paper jam? Often that will clear false errors. If not, look for the sensors. They should be somewhere along the paper path, and consist of a plastic lever that will be pushed down as the paper moves past them. Usually these levers have springs attached - if the spring comes off, it will register a paper jam. You'll probably have to take off some of the housing to get to them. I'm not sure this will help much, but since I found it I'll post it. The user's manual: http://edocutek.com/Manuals/DR6080_9080C_UG.pdf If the sensor needs replaced (most often due to something simple like a piece of plastic breaking on it), you can order new sensor PCB assemblies (sensor and its small control board) here: http://www.precisionroller.com/manufacturers/canon-dr6080.html They also sell a parts manual, but it's a bit pricey.
Posted on Sep 08, 2007
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Canon DR9080c - getting error code P00 which means paper jam in the scanner but there is no paper in there & I have cleaned all the sensors! What else could this be?
This is a common problem in 9080C. When the top cover is closed, the sensor sends light and it is reflected thro the black cover in the bottom. Then the scanner assumes the cover is closed. Any obstruction is treated as P00 error. You will notice three small oval & round shaped clear plastic. Clean them with a brush and ensure the edges are clean. Light goes thru one side and come thro the other, which is sensed by the unit placed in the top cover.
S. Mohan, India
Sep 12, 2013 | Canon DR-9080C Path-Through Scanner
Error code P00
Paper in the scanner. Clean all the sensors.
Jul 27, 2011 | Canon DR 5080C Path-Through Scanner
P00 Error with no paper jam
See this link:
Look for reference to P00 error
http://74.125.47.132/search?q=cache:CSQKZT0GyBEJ:downloads.canon.com/cpr/software/scanners/5080QRG.pdf+DR-5080C+p00+error&hl=en&ct=clnk&cd=1&gl=us
Jan 23, 2009 | Canon DR 5080C Path-Through Scanner
CANNON SCANNER 7580...ERROR P00
Canon error numbers are logical! Error starting with 'P' is paper related. If there is already soem paper inside the scanner while inititalising, u will get this error. Check for shreds of paper in the paper path. (Error starting with 'C' is Cover and 'E' isn Engineer reqd)
S. Mohan, Chennai, india
Jan 15, 2009 | Canon DR-7580
Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
Hi have a p00 error on a canon 7580 scanner does anyone know what this is?
The P00 is a paper jam code .
Check if there is any small bit of paper stuck in any of the sensors. Remove the rubber rollers, clean and refit them.
Hope this helps you.
Thanks for using Fixya
SAM ANDERSON
Sep 17, 2008 | Office Equipment & Supplies
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
867 people viewed this question
Clive
Clive
old marine
old marine
